dell inspiron 1100 compal_la-1452_rev1.0 schematic
dell inspiron 1100=1=compal_la-1452_rev1.0.pdf
The Compal LA-1452 motherboard, branded as Dell-Compal Abacus/TangII, is a Revision 1.0 design dated November 26, 2002. It supports a uFCBGA/uFCPGA Northwood CPU platform with an Intel ICH4 southbridge. Graphics are handled via AGP 4X (1.5V) through an AGP GRAPHIC/CHRONTEL solution. The embedded controller is an NS EC87591L, and the audio codec is a STAC9750. The system BIOS is provided by SST. Power management is handled by a MAX1632 charging IC, with additional power ICs including ISL6215, ISL6225, CM2843, and ISL6219. Memory architecture consists of DDR memory across two DDR-DIMM slots. The board integrates an ADM1032 thermal sensor, a PCI4510/PCI1510 card reader controller, and a BCM-4401 LAN IC. Wireless connectivity is supported via a MiniPCI connector.
Q: What is the board number and revision for this motherboard?
A: The board number is LA-1452, Revision 1.0.
A: The embedded controller is an NS EC87591L.
Q: What BIOS IC manufacturer is used on this motherboard?
A: The BIOS IC is manufactured by SST.
A: The charging IC is a MAX1632.
| Brand | Dell-Compal |
| Model | Abacus/TangII |
| Project Code | Abacus/TangII |
| Board Number | LA-1452 |
| Date | Tuesday, November 26, 2002 |
| CPU Platform | uFCBGA/uFCPGA Northwood |
| PCH / Southbridge | ICH4 |
| GPU Type | AGP GRAPHIC/CHRONTEL |
| Graphics Architecture | AGP 4X (1.5V) |
| EC / KBC | NS EC87591L |
| Audio Codec | STAC9750 |
| BIOS / SPI Flash | SST |
| Charging IC | MAX1632 |
| Power IC(s) | ISL6215, ISL6225, CM2843, ISL6219 |
| RAM Type | DDR |
| RAM Architecture | Memory BUS (DDR) |
| RAM Quantity / Slots | DDR-DIMM X2 |
| Thermal Sensor | ADM1032 |
| Card Reader IC | PCI4510/PCI1510 |
| LAN IC | BCM-4401 |
| WiFi / WLAN IC | MiniPCI CONN |
LA-1452
ICH4
AGP 4X (1.5V)
NS EC87591L
STAC9750
MAX1632
CM2843
ISL6215
ISL6219
ISL6225
DDR
ADM1032
PCI4510 / PCI1510
BCM 4401
MiniPCI CONN
LA-1452
ICH4
AGP 4X (1.5V)
NS EC87591L
STAC9750
MAX1632
CM2843
ISL6215
ISL6219
ISL6225
DDR
ADM1032
PCI4510 / PCI1510
BCM 4401
MiniPCI CONN
