dell inspiron 15 3531 compal_la-b481p_rev2.0 schematic
dell inspiron 15 3531=1=compal_la-b481p_rev2.0.pdf
This Dell ZBW00 motherboard, manufactured by Compal Electronics with board number LA-B481P revision 2.0 dated 2014-03-10, is built on the Intel Bay Trail M platform featuring an FH8065301729601 SR1UX C0 2.17G FCBGA 1170 N2830 CPU. The graphics architecture is OAK MLK UMA, confirming an integrated-only GPU configuration. System memory consists of a single 204-pin DDR3L SO-DIMM supporting dual-channel 1.35V DDR3L 1066/1333. The embedded controller is an ENE KB9012, and the audio codec is an ALC3223. The BIOS is stored on an 8MB SPI ROM operating at 1.8V. Connectivity includes an FE1.1s(STT) LAN IC, WLAN/BT4.0 support, an RTD2132N HDMI level shifter, and an RTS5170 card reader IC.
Q: What is the board number and revision of this Dell ZBW00 motherboard?
A: The board number is LA-B481P, revision 2.0.
A: The embedded controller is an ENE KB9012.
A: The BIOS is an 8MB SPI ROM operating at 1.8V.
A: The system supports a single 204-pin DDR3L SO-DIMM with dual-channel 1.35V DDR3L 1066/1333.
Q: What is the graphics configuration?
A: The graphics architecture is OAK MLK UMA, indicating an integrated GPU only, with no discrete GPU.
| Brand | Dell |
| Model | ZBW00 |
| Board Number | LA-B481P |
| Revision | 2.0 |
| Date | 2014-03-10 |
| CPU Platform | Intel Bay Trail M |
| CPU Model | FH8065301729601 SR1UX C0 2.17G FCBGA 1170 N2830 |
| GPU Type | UMA |
| Graphics Architecture | OAK MLK UMA |
| EC / KBC | ENE KB9012 |
| Audio Codec | ALC3223 |
| BIOS / SPI Flash | SPI ROM 1.8V (8MB) |
| RAM Type | DDR3L |
| RAM Architecture | Dual Channel 1.35V DDR3L 1066/1333 |
| RAM Quantity / Slots | 204pin DDR3L-SO-DIMM X1 |
| Card Reader IC | RTS5170 |
| LAN IC | FE1.1s(STT) |
| WiFi / WLAN IC | WLAN/BT4.0 |
| HDMI Level Shifter | RTD2132N |
