dell_inspiron_15_3531_series__compal_la-b481p_rev_2.0_dr_bios.com dell_inspiron_15_3531_series__compal_la-b481p_rev_2.0_dr_bios.com schematic
dell inspiron 15 3531 series compal la-b481p rev 2.0.pdf
This Compal LA-B481P Rev 2.0 motherboard, designed for the Dell ZBW00 model, is built on the Intel Bay Trail MOAK MLK UMA platform. The board is powered by an Intel N2830 processor (FH8065301729601 SR1UX C0 2.17G) in an FCBGA 1170 package. System memory is provided by a single 204-pin DDR3L SO-DIMM slot supporting dual-channel 1066/1333 MHz memory. The embedded controller is an ENE KB9012, and the audio subsystem uses a Realtek ALC3223 codec. Storage and connectivity are managed through a 1.8V 8MB SPI ROM for BIOS, a Realtek RTS5170 card reader, a FE1.1s(STT) USB hub/LAN controller, and integrated WLAN/BT 4.0. Video output is handled by an RTD2132N HDMI level shifter.
Q: What is the board number and revision for this Dell ZBW00 motherboard?
A: The board number is LA-B481P, revision 2.0.
A: The embedded controller is an ENE KB9012.
A: It supports a single 204-pin DDR3L SO-DIMM module at 1066/1333 MHz in dual-channel mode.
A: The BIOS is stored on a 1.8V 8MB SPI ROM.
| Brand | Dell / Compal |
| Model | ZBW00 |
| Board Number | LA-B481P |
| Revision | 2.0 |
| Date | 2014/03/10 |
| CPU Platform | Intel Bay Trail MOAK MLK UMA |
| CPU Model | FH8065301729601 SR1UX C0 2.17G FCBGA 1170 N2830 |
| EC / KBC | ENE KB9012 |
| Audio Codec | ALC3223 |
| BIOS / SPI Flash | SPI ROM 1.8V (8MB) |
| RAM Type | DDR3L 1066/1333 |
| RAM Quantity / Slots | 204pin DDR3L-SO-DIMM X1 |
| Card Reader IC | RTS5170 |
| LAN IC | FE1.1s(STT) |
| WiFi / WLAN IC | WLAN/BT4.0 |
| HDMI Level Shifter | RTD2132N |
