dell inspiron 15 5000 series la-b012p zavc0_rev1.0 schematic
dell inspiron 15 5000 series=1=la-b012p zavc0_rev1.0.pdf
This Compal LA-B012P reference design, branded as Dell Maple, is built on the Intel Shark Bay ULT platform with an Intel Broadwell ULT-U processor in a BGA 1168 package. The board supports both UMA and discrete AMD 25W graphics configurations. System memory consists of two DDRIII-DIMM slots supporting up to 8GB of DDR3L 1600 MHz in dual-channel architecture. The embedded controller is an ENE KB9012 communicating via the LPC bus. The SPI ROM for BIOS is 8MB in capacity. Audio is handled by a Realtek ALC3234 codec. Networking includes a Realtek RTL8106E Ethernet controller and WiFi/WiGi with Bluetooth 4.0. The card reader and charging IC are both provided by the RTS5179 controller.
A: The ENE KB9012 embedded controller is used, communicating via the LPC bus.
Q: What is the BIOS flash capacity on this board?
A: The SPI ROM is 8MB in capacity.
A: It uses the Intel Shark Bay ULT platform with an Intel Broadwell ULT-U processor in a BGA 1168 package.
Q: What is the memory architecture of this board?
A: It supports dual-channel DDR3L 1600 MHz memory via two DDRIII-DIMM slots, with a maximum of 8GB.
| Brand | Dell / Compal |
| Model | Maple |
| Project Code | Maple 14"/15" Value |
| Board Number | DA8000WL000 LA-B012P |
| Date | 2014-01-21 |
| CPU Platform | Intel Shark Bay ULT |
| CPU Model | Intel Broadwell ULT-U |
| GPU Type | UMA / DIS AMD 25W/S3 |
| Graphics Architecture | AMD 25W |
| EC / KBC | ENE KB9012 |
| EC/KBC Package | LPC Bus |
| Audio Codec | ALC3234 |
| BIOS Flash Capacity | 8MB |
| Charging IC | RTS5179 |
| RAM Type | DDR3L |
| RAM Quantity / Slots | DDRIII-DIMM X2 |
| LAN IC | RTL8106E |
| WiFi / WLAN IC | WiFi/WiGi/BT4.0 |
| Card Reader IC | RTS5179 |
