dell inspiron 1520 dafm5bmb6a0-c rev-2a 1113 1
The Quanta Computer C & G UMA 2A motherboard, revision 1A, dated November 13, 2006, is built around the Intel Merom CPU platform using a 478 Micro-FCPGA socket paired with an ICH8-M southbridge. The board utilizes UMA graphics architecture and supports two DDR2-SODIMM slots. The embedded controller is an MEC5025 in a 128-pin VTQFP package with 128KB of flash memory, indicating programmable capability. System firmware is stored on a SPI flash device. Audio is handled by a STAC9200 codec, while networking is provided by a BCM4401 B0 LAN IC. Power management includes an ISL6260 CPU VR controller and a BCCK505 battery charger IC. A R5C833 controller manages the integrated card reader functionality.
A: The motherboard uses an MEC5025 embedded controller in a 128-pin VTQFP package with 128KB of onboard flash memory.
Q: What type of BIOS flash is used?
A: The system uses a SPI flash device for BIOS storage.
Q: What is the CPU platform and socket?
A: The platform is Intel Merom using a 478 Micro-FCPGA socket.
Q: What charging IC is used?
A: The battery charger IC is a BCCK505.
| Brand | QUANTA COMPUTER |
| Model | C & G UMA 2A |
| Motherboard Manufacturer | QUANTA COMPUTER |
| Project Code | C & G UMA 2A |
| Board Number | C&G UMA M/B PCB |
| Revision | 1A |
| Date | Monday, November 13, 2006 |
| CPU Platform | Merom |
| CPU Socket | 478 Micro-FCPGA |
| PCH / Southbridge | ICH8-M |
| Graphics Architecture | UMA |
| EC / KBC | MEC5025 |
| EC/KBC Package | 128 Pins VTQFP |
| EC/KBC Programmable | 128KB Flash |
| Audio Codec | STAC9200 |
| BIOS / SPI Flash | SPI Flash |
| Charging IC | BCCK505 |
| Power IC(s) | ISL6260 |
| RAM Type | DDR2-SODIMM |
| LAN IC | BCM4401 B0 |
| Card Reader IC | R5C833 |
