Schematic Dell Inspiron 3501 LA-K036P Schematic
BrandDell
ModelBullseye TGL
Motherboard ManufacturerCompal
Project CodeBullseye TGL
Board NumberDA8001QB000
PCB NumberDA8001QB000 PCB 2X2 LA-K036P
Revision1.0 (A00)
Date2021-03-08
CPU PlatformTGL-U
EC / KBCMEC1515
GPU TypeN17S-G3
dGPU Chip NumberN17S-G3-A1_BGA_595P
dGPU to UMA Conversion SupportUMA@ : not Support external Graphic card
CPU ModelFH8069004531901 QVBS B1 1.8G (Celeron), FH8069004531802 QVBK B1 2G (Pentium), FH8069004531502 QVBG B1 3G (i3), FH8069004531301 SRK05 B1 2.4G (i5), FH8069004529905 QVBA B1 2.8G (i7), FH8069004530601 QVBD B1 2.4G (i5), FH8069004530104 SRK02 B1 2.8G (i7)
This Compal-manufactured Dell Bullseye TGL motherboard, board number DA8001QB000 PCB 2X2 LA-K036P revision 1.0 (A00) dated 2021-03-08, is built on the TGL-U platform. The embedded controller is a MEC1515. The discrete GPU is an N17S-G3-A1 BGA 595P. The board supports multiple CPU options including Celeron FH8069004531901, Pentium FH8069004531802, Core i3 FH8069004531502, Core i5 FH8069004531301 and FH8069004530601, and Core i7 FH8069004529905 and FH8069004530104. The schematic explicitly notes that UMA configuration does not support an external graphics card.
A: The EC/KBC is a MEC1515.
Q: What GPU is used on this motherboard?
A: The discrete GPU is an N17S-G3-A1 BGA 595P.
Q: Does this motherboard support dGPU to UMA conversion?
A: No. The schematic explicitly states UMA@ does not support an external graphics card.
Q: What CPU models are supported on this motherboard?
A: Supported CPUs include Celeron FH8069004531901, Pentium FH8069004531802, Core i3 FH8069004531502, Core i5 FH8069004531301 and FH8069004530601, and Core i7 FH8069004529905 and FH8069004530104.
  • Dell Inspiron 3501 LA-K036P Schematic.pdf
