send 8 mb fileunlock bios bin Dell inspiron15 3510 gdm51 la l242p rev 1.0
send 8 mb file
I test this bin bios of you (https://dr-bios.com/attachments/la-l242p-zip.70481/)my friend I test the 128 of my pc the pc does not start I have a problem in my bios bin and I check your bios bin the pc it gives several colors white then yellow then towards
see, now the problem, not a password, now the problem in the original 16mb bin, the pc with the original does not work is with your bin it givesHow to Remove Dell Laptop Bios Password
Dell laptop has different series, and each of them usually has a different type of password. For example, removing Bios password of Inspiron series of Dell is different from removing Bios password of the Latitude series of Dell, and there are different types of passwords as well and removing...dr-bios.com
on my pc there is a bios password when we test the new 16mb bin it gives several colors, after that I test the original bin the pc no longer starts just with the original binHow to Remove Dell Laptop Bios Password
see, now the problem, not a password, now the problem in the original 16mb bin, the pc with the original does not work is with your bin it givessee, now the problem, not a password, now the problem in the original 16mb bin, the pc with the original does not work is with your bin it gives
helmi h , Ali Shaikh , Vahab Hemmati , Azam Ghalib , Salimeh Bolboli , appleguys , user37894 , tiborrr , Kanini Technology , user57790 , s2qers2qer , vovados1 , rscomputer , ramamurthi
