Schematic Dell latitude 12 7210 LA-J321P Schematic
BrandDell/Compal
ModelAugusta MLK Comet Lake U
Motherboard ManufacturerCompal Electronics, Inc.
Board NumberLA-J321P
Revision0.2 (X01) DVT1
Date2019-10-17
CPU PlatformComet Lake U
EC / KBCMEC5107
BIOS Flash Exact ModelWINBOND, XMC, GD
TPMNuvoton TPM
Document Number1100
This Dell/Compal Augusta MLK Comet Lake U motherboard, board number LA-J321P revision 0.2 (X01) DVT1 dated 2019-10-17, is built on the Intel Comet Lake U platform. The embedded controller is a MEC5107, which supports authentication enable/disable configurations. The BIOS SPI flash supports three ROM options: WINBOND, XMC, and GD. The system includes a Nuvoton TPM module. The schematic document number is 1100, produced by Compal Electronics, Inc.
Q: What BIOS IC models are used on this motherboard?
A: The BIOS ROM supports three options: WINBOND, XMC, and GD.
Q: Is the EC/KBC programmable on this motherboard?
A: The EC is a MEC5107, which supports Auth enabled (Auth_En_D4) and Auth disabled (Auth_Dis_D4) configurations.
Q: What is the board number and revision for this motherboard?
A: The board number is LA-J321P, revision 0.2 (X01) DVT1.
  • Dell latitude 12 7210 LA-J321P Schematic.PDF
