dell latitude d810 compal la-2111 rev x00
This DELL LA2111 Rev 0.3 schematic, dated February 9, 2004, details a motherboard built around the Intel Dothan CPU platform in a uFCPGA socket. The platform utilizes an ICH6 southbridge and a GMCH-M northbridge. The system memory architecture is DDR2, configured as two SO-DIMM slots. The embedded controller is a Macallen III, and the system BIOS is stored on an SST39VF080 flash IC. Audio is handled by a STAC9751 AC97 codec, while networking is provided by a BCM5751M LAN controller. The charging IC is identified as 7002, and the system includes a PCI6515 card reader controller and a U609 BGA USB hub IC.
A: The BIOS is stored on an SST39VF080 flash IC.
A: The embedded controller is a Macallen III.
A: The memory architecture is DDR2, configured as two SO-DIMM slots.
A: The LAN controller is a BCM5751M.
| Brand | DELL |
| Board Number | LA2111 |
| Revision | 0.3 |
| Date | Monday, February 09, 2004 |
| CPU Platform | Dothan |
| CPU Socket | uFCPGA |
| PCH / Southbridge | ICH6 |
| EC / KBC | Macallen III |
| Audio Codec | STAC9751 |
| BIOS / SPI Flash | SST39VF080 |
| LAN IC | BCM5751M |
| Charging IC | 7002 |
| RAM Type | DDR2 |
| RAM Architecture | SO-DIMM X2 |
| Card Reader IC | PCI6515 |
| USB Hub IC | U609 BGA |
| WiFi / WLAN IC | Marvell |
