dell latitude d810 compal_la-2112_rev0.4 schematic
dell latitude d810=1=compal_la-2112_rev0.4.pdf
This Dell Compal LA-2112 motherboard, revision X03, is built around the uFCPGA Dothan CPU platform with an ICH6 southbridge. Graphics are handled by a Macallen III GPU. The system uses DDR2 memory across two SO-DIMM slots. The BIOS and EC/KBC functions are both provided by an SST39VF080 flash IC. Audio is managed by a TAC9751 codec, and networking is handled by a BCM5751 LAN IC. Charging is controlled by a BATTIN IC, and a PCI6515 IC manages the card reader. USB connectivity is supported by a U609 BGA hub IC.
A: The BIOS is an SST39VF080.
Q: What EC/KBC IC is used on this motherboard?
A: The EC/KBC is an SST39VF080.
A: This motherboard supports DDR2 memory via two SO-DIMM slots.
A: The LAN IC is a BCM5751.
| Brand | DELL |
| Motherboard Manufacturer | Compal |
| Board Number | LA-2112 |
| Revision | X03 |
| Date | Thursday, October 28, 2004 |
| CPU Platform | uFCPGA Dothan |
| PCH / Southbridge | ICH6 |
| GPU Type | Macallen III |
| EC / KBC | SST39VF080 |
| Audio Codec | TAC9751 |
| BIOS / SPI Flash | SST39VF080 |
| Charging IC | BATTIN |
| RAM Type | DDR2 |
| RAM Quantity / Slots | SO-DIMM X2 |
| LAN IC | BCM5751 |
| Card Reader IC | PCI6515 |
| USB Hub IC | U609 BGA |
