Dell Latitude E5250 LA-A891P
This Dell Houston 12" UMA Dock motherboard, manufactured by Compal under board number LA-A891P revision 1.0 (A00), is built around the Intel Broadwell U processor platform. The system firmware is stored on a W25Q32BVSSIQ SPI flash with 64M 4K sector capacity, with a compatible W25Q64CVSSIQ alternative. Embedded controller functionality is handled by the SMSC KBC MEC5085. Audio is provided by an ALC3235 HDA codec, while networking is managed by an Intel Clarkville I218L LAN IC. The board supports DDR3L memory across four DIMM banks. Peripheral connectivity includes an O2 Micro OZ777FJ2LN-B card reader, a Parade PS8339 HDMI level shifter, a PI3USB3102ZLEX USB hub, and a TPS2544 USB power share controller. Security features include a discrete AT97SC3205 TPM and a BCM20793 NFC controller alongside a BCM5882 smart card reader.
Q: What BIOS IC models are used on this motherboard?
A: The primary BIOS flash IC is a W25Q32BVSSIQ with 64M 4K sector capacity. A compatible alternative is the W25Q64CVSSIQ.
A: The embedded controller is an SMSC KBC MEC5085.
A: This motherboard supports DDR3L memory in DIMM form factor across four banks (BANK 0, 1, 2, 3).
Q: What LAN controller is integrated on this motherboard?
A: The integrated LAN controller is an Intel Clarkville I218L.
| Brand | Dell |
| Model | Houston 12" UMA Dock M/B |
| Motherboard Manufacturer | Compal |
| Board Number | LA-A891P |
| Revision | 1.0 (A00) |
| Date | 2014-08-04 |
| CPU Platform | Broadwell U Processor |
| EC / KBC | SMSC KBC MEC5085 |
| Audio Codec | ALC3235 |
| BIOS Flash Exact Model | W25Q32BVSSIQ |
| BIOS Flash Capacity | 64M 4K sector |
| Compatible BIOS IC Models | W25Q64CVSSIQ |
| LAN IC | Intel Clarkville I218L |
| Card Reader IC | O2 Micro OZ777FJ2LN-B |
| TPM | Discrete TPM AT97SC3205 |
| HDMI Level Shifter | Parade PS8339 |
| USB Hub IC | PI3USB3102ZLEX |
| USB Switch | NX3DV221GM |
| USB Power Share IC | TPS2544 |
| Smart Card Controller | TDA8034HN |
| NFC Controller | BCM20793 |
| Smart Card Reader | BCM5882 |
| SATA Re-Driver | PERICOM (SA00004H100) |
| DP to HDMI Converter | Parade PS8338 |
| DP to VGA Converter | IDT VMM3320 |
| RAM Type | DDR3L |
| RAM Architecture | DDR3L-DIMM |
| RAM Quantity / Slots | BANK 0, 1, 2, 3 |
