Schematic dell m5010 berry crt board a00 0204 09698-1 schematic
dell m5010 berry crt board a00 0204 09698-1 1
BrandWistron Corporation
ModelBerry CRT Board
Project Code91.4HH01.001
Board Number09698-1
RevisionA00
DateThursday, February 04, 2010
CPU PlatformArrandale
PCH / SouthbridgeIntel PCH
This Wistron Berry CRT Board, project code 91.4HH01.001 and PCB P/N 09698-1, is a revision A00 document dated February 4, 2010. The platform is built around an Intel PCH southbridge paired with an Arrandale CPU platform. The schematic details the CRT and USB I/O board connector layout, including the CRT RGB, H/VSYNC, and SMBUS signal routing, as well as USB2 and USB3 port connections. The document specifies a core design with a DY (depop) component note for the Arrandale platform.
Q: What is the board number and project code for this Wistron Berry CRT Board?
A: The PCB P/N is 09698-1 and the project code is 91.4HH01.001.
Q: What CPU platform and PCH does this schematic support?
A: The schematic is designed for an Arrandale CPU platform with an Intel PCH southbridge.
Q: What is the revision and date of this schematic?
A: The schematic is revision A00, dated Thursday, February 4, 2010.
  • Dell_M5010=1=Berry_crt_board_a00_0204_09698-1.pdf
