Schematic dell n5040 dv15 cp a00 mb 0422 ins 10263-1 schematic
dell n5040 dv15 cp a00 mb 0422 ins 10263-1 1
BrandWistron Corporation
ModelEnrico/Caruso 15" UMA
Project Code91.4IP01.001
Board Number48.4IP01.011
Revision10263-1
DateFriday, April 22, 2011
CPU PlatformIntel Ibex Peak-M / Arrandale
CPU SocketrPGA988A
EC / KBCNPCE781BA0DXN
EC/KBC Programmable256kB Flash ROM
Audio CodecIDT92HD87B1P
BIOS / SPI Flash4MB Flash ROM
Charging ICBQ24707
Charger ArchitectureMAXIM CHARGER
Power IC(s)ISL62882, RT8207, TPS51123, RT8237A, TPS51611, APW7153B
RAM TypeDDRIII 1066
RAM ArchitectureDual Channel (Channel A, Channel B)
RAM Quantity / Slots2 (Slot 0, Slot 1)
Card Reader ICRTS5138
LAN ICRealtek RTL8105E-VC
WiFi / WLAN IC802.11b/g/n BT V3.0+HS Mini-Card
HDMI Level ShifterSLG8SP5956
This Wistron Enrico/Caruso 15" UMA motherboard, project code 91.4IP01.001 and board number 48.4IP01.011 revision 10263-1, is built around the Intel Ibex Peak-M platform supporting an rPGA988A Arrandale CPU. The system uses an NPCE781BA0DXN EC/KBC with 256kB of internal flash ROM for firmware storage. The main BIOS is stored on a 4MB SPI flash ROM. Memory architecture consists of two DDRIII 1066 slots configured in dual-channel mode. Power management is handled by a BQ24707 charger IC and a suite of DC/DC converters including ISL62882, RT8207, TPS51123, RT8237A, TPS51611, and APW7153B. Audio is provided by an IDT92HD87B1P codec. Networking includes a Realtek RTL8105E-VC 10/100 NIC and an 802.11b/g/n with Bluetooth V3.0+HS Mini-Card. A Realtek RTS5138 card reader and an SLG8SP5956 HDMI level shifter are also present.
Q: What EC/KBC is used on this motherboard and is it programmable?
A: The EC/KBC is an NPCE781BA0DXN with 256kB of internal Flash ROM, making it programmable.
A: The motherboard uses a 4MB SPI Flash ROM for the main BIOS.
A: The board supports two DDRIII 1066 SO-DIMM slots configured in dual-channel mode (Channel A and Channel B).
A: The charging IC is a BQ24707, part of a MAXIM CHARGER architecture.
Q: What LAN IC is used?
A: The LAN IC is a Realtek RTL8105E-VC 10/100 NIC.
  • DR-BIOS.COM_Dell_N5040=1=DV15_CP_A00_MB_0422_INS_10263-1.zip
