Salim Badakhshan
Dell OptiPlex 3070 D9.5-MFF COUGAR-MLK A00 Schematic
The Pegatron D9.5_MFF IPCFL-CG motherboard, board number A2197 revision A00, is a compact 170x172.3mm platform designed for Intel LGA-1151 processors up to 35W. The platform is built around the Intel H370 PCH and features dual SO-DIMM DDR4-2667 memory slots across Channel A and B. Graphics are handled by a GPU MESO-S3-XT with dedicated 256Mx16bit DDR3 VRAM. The system is managed by an SMSC5553 EC/KBC and boots from a 16MB SPI flash ROM. Audio is provided by an ALC3234 codec, while networking is handled by a Realtek RTL8111HS LAN controller. Power delivery is managed by a multi-rail solution including RT8231B, RT8204, AOZ2263QI_10, RT6575B, NCP81203, NCP81151MNTBG, APL5933, RT9053, and APL3523AQB regulators. The board also integrates a CYPD2122 USB hub controller and an NPCT750JAAY TPM module.
Q: What is the board number and project code for this motherboard?
A: The board number is A2197, and the project code is D9.5_MFF IPCFL-CG.
Q: What BIOS flash IC is used on this motherboard?
A: The motherboard uses a 16MB SPI flash ROM.
A: The EC/KBC controller is an SMSC5553.
Q: What is the charging IC and power architecture?
A: The charging IC is an RT8231B, with additional power regulation provided by RT8204, AOZ2263QI_10, RT6575B, NCP81203, NCP81151MNTBG, APL5933, RT9053, and APL3523AQB.
Q: What LAN and audio controllers are used?
A: The LAN controller is a Realtek RTL8111HS, and the audio codec is an ALC3234.
| Brand | Pegatron |
| Motherboard Manufacturer | Pegatron Corp. |
| Project Code | D9.5_MFF IPCFL-CG |
| Board Number | A2197 |
| Revision | A00 |
| Date | Tuesday, January 29, 2019 |
| CPU Platform | Intel Processor |
| CPU Socket | LGA-1151 Pin Socket |
| PCH / Southbridge | Intel H370 |
| GPU Type | GPU MESO-S3-XT |
| Graphics Architecture | VRAM DDR3 256Mx16bit |
| EC / KBC | SMSC5553 |
| Audio Codec | ALC3234 |
| BIOS / SPI Flash | SPI FLASH 16M |
| Charging IC | RT8231B |
| Power IC(s) | RT8204, AOZ2263QI_10, RT6575B, NCP81203, NCP81151MNTBG, APL5933, RT9053, APL3523AQB |
| RAM Type | SO-DIMM DDR4 2667 |
| RAM Architecture | Channel A, Channel B |
| LAN IC | Realtek RTL8111HS |
| WiFi / WLAN IC | WLAN & BT |
| Card Reader IC | TPM NPCT750JAAY |
| USB Hub IC | CYPD2122 |
D9.5_MFF
Project Code
A2197
Board Number
Intel Processor
H370
PCH / Southbridge
GPU MESO-S3-XT
Graphics
Graphics
SMSC5553
ALC3234
RT8231B
Charging / PD IC
AOZ2263QI_10
Power IC
APL3523AQB
Power IC
APL5933
Power IC
NCP81151MNTBG
Power IC
NCP81203
Power IC
RT6575B
Power IC
RT8204
Power IC
RT9053
Power IC
SO-DIMM DDR4 2667
RTL8111HS
LAN Controller
TPM NPCT750JAAY
Card Reader IC
CYPD2122
USB Controller
D9.5_MFF
Project Code
A2197
Board Number
Intel Processor
H370
PCH / Southbridge
GPU MESO-S3-XT
Graphics
Graphics
SMSC5553
ALC3234
RT8231B
Charging / PD IC
AOZ2263QI_10
Power IC
APL3523AQB
Power IC
APL5933
Power IC
NCP81151MNTBG
Power IC
NCP81203
Power IC
RT6575B
Power IC
RT8204
Power IC
RT9053
Power IC
SO-DIMM DDR4 2667
RTL8111HS
LAN Controller
TPM NPCT750JAAY
Card Reader IC
CYPD2122
USB Controller
