dell quanta vm8m d3a 0512 2230 rev 1a 0508
The QUANTA COMPUTER VM8M1A is an Intel UMA motherboard revision D3A, dated Friday, May 08, 2009. It is built around the Penryn CPU platform using a 478 Micro-FCPGA socket, paired with the Cantiga graphics architecture and an ICH9-M southbridge. The system supports DDR2 memory via two SODIMM slots. The embedded controller is an ITE8502, and the BIOS flash is a 2M byte SPI ROM. Audio is handled by a CX20583-10Z codec, while networking is provided by an RTL8111DL LAN IC and an SLG8SP513V(QFN-64) WLAN module. The charging IC and card reader controller are both R5U230. Thermal management is monitored by an EMC1423-1-AIZL-TR sensor.
Q: What is the EC/KBC used on this motherboard?
A: The embedded controller is an ITE8502.
A: The BIOS flash is 2M bytes.
Q: What is the charging architecture on this motherboard?
A: The charging architecture is BATT CHARGER, using an R5U230 charging IC.
Q: What is the LAN IC on this motherboard?
A: The LAN IC is an RTL8111DL.
| Brand | QUANTA COMPUTER |
| Model | VM8M1A |
| Motherboard Manufacturer | QUANTA COMPUTER |
| Board Number | VM8M1A |
| Revision | D3A |
| Date | Friday, May 08, 2009 |
| CPU Platform | Penryn |
| CPU Socket | 478 Micro-FCPGA |
| PCH / Southbridge | ICH9-M |
| GPU Type | Cantiga |
| Graphics Architecture | Intel UMA |
| EC / KBC | ITE8502 |
| Audio Codec | CX20583-10Z |
| BIOS / SPI Flash | 2M bytes |
| Charging IC | R5U230 |
| Charger Architecture | BATT CHARGER |
| RAM Type | DDR2 |
| RAM Architecture | SODIMM |
| RAM Quantity / Slots | *2 |
| Card Reader IC | R5U230 |
| LAN IC | RTL8111DL |
| WiFi / WLAN IC | SLG8SP513V(QFN-64) |
| Thermal Sensor | EMC1423-1-AIZL-TR |
