dell vostro 3500 wistron dw40_50 winery14 io bd schematic
wistron dw40_50 winery14 io bd.pdf
wistron dw50 winery15 dcin bd.pdf
wistron dw50 winery15_revsa.pdf
This Wistron Corporation DW40_I/O_BOARD, project code 91.4ES01.001 and PCB number 48.4ES06.0SA, is an I/O board dated September 8, 2009, with revision 09630-SA. The board integrates an RTS5138-GR-GP card reader controller at U3201 and a W83L351YG-GP ExpressCard controller at U4001. The schematic includes power rails such as +1.5V_RUN, +3.3V_RUN, +3.3V_ALW, and +3.3V_NEW_AUX, with specific current ratings for the ExpressCard slot. The design also features a 26-pin ExpressCard connector and a USB interface for the card reader.
Q: What card reader IC is used on this I/O board?
A: The card reader IC is an RTS5138-GR-GP at U3201.
Q: What ExpressCard controller is used on this board?
A: The ExpressCard controller is a W83L351YG-GP at U4001.
Q: What is the PCB number for this Wistron I/O board?
A: The PCB number is 48.4ES06.0SA.
This Wistron Corporation document, dated Friday, September 04, 2009, is designated as DW50_DCIN_BOARD with project code 91.4ET01.001 and PCB P/N 48.4ET06.0SA, revision 09628-SA. The board is a DC-IN and USB connector sub-board, featuring a USB power switch implemented with a TPS2062AD-GP IC and USB ESD protection provided by a PRTR5V0U2X-GPDY device. The document is authored by Wistron Corporation, located at 21F, 88, Sec.1, Hsin Tai Wu Rd., Hsichih, Taipei Hsien 221, Taiwan, R.O.C., under the Core Design group.
Q: What is the project code and PCB part number for this board?
A: The project code is 91.4ET01.001 and the PCB P/N is 48.4ET06.0SA.
Q: What USB power switch IC is used on this board?
A: The USB power switch IC is a TPS2062AD-GP.
Q: What USB ESD protection IC is used on this board?
A: The USB ESD protection IC is a PRTR5V0U2X-GPDY.
This Dell Vostro Calpella SA motherboard, manufactured by Wistron Corporation (Project Code 91.4ET01.001, Board Number 48.4ET05.0SA, PCB P/N 09289, Revision SA, dated 2009-09-09), is built on the Intel Arrandale CPU platform with an Intel Ibex Peak-M PCH. The discrete graphics architecture features an Nvidia N11M-GE (40nm) GPU. System management is handled by a NUVOTON NPCE781BA0DX EC/KBC in a 128-pin package, supported by a 256kB Flash ROM. The system BIOS resides on a 4MB SPI Flash ROM. Audio is provided by an IDT 92HD81 codec. Power management includes a BQ24745 charger and multiple DC/DC converters (ISL62883, TPS51125, TPS51116, TPS51218, ADP3211, APL5930, RT9025). Memory configuration supports two slots of DDRIII 1066 RAM. Connectivity features a Realtek RTL8111DL LAN IC, a Realtek RTS5138 card reader, 802.11a/b/g/n WiFi, and an SLG8SP585 HDMI level shifter.
A: The motherboard uses a NUVOTON NPCE781BA0DX EC/KBC in a 128-pin package, with a dedicated 256kB Flash ROM.
A: The BIOS is stored on a 4MB SPI Flash ROM.
Q: What is the graphics architecture of this motherboard?
A: This motherboard uses a discrete (DIS) graphics architecture with an Nvidia N11M
| Project Code | 91.4ES01.001 |
| Board Number | DW40_I/O_BOARD |
| Revision | 09630-SA |
| Date | Tuesday, September 08, 2009 |
| PCB Number | 48.4ES06.0SA |
| Card Reader IC | RTS5138-GR-GP (U3201) |
| ExpressCard Controller | W83L351YG-GP (U4001) |
| Project Code | 91.4ET01.001 |
| PCB P/N | 48.4ET06.0SA |
| Revision | 09628-SA |
| Date | Friday, September 04, 2009 |
| Document Number | DW50_DCIN_BOARD |
| USB Power Switch IC | TPS2062AD-GP |
| USB ESD Protection IC | PRTR5V0U2X-GPDY |
| Brand | Dell |
| Model | Vostro |
| Board Number | 48.4ET05.0SA |
| PCB P/N | 09289 |
| Revision | SA |
| Date | 2009-09-09 |
| CPU Platform | Intel Arrandale |
| PCH / Southbridge | Intel Ibex Peak-M |
| GPU Type | Nvidia N11M-GE (40nm) |
| Graphics Architecture | DIS (Discrete) |
| EC / KBC | NUVOTON NPCE781BA0DX |
| EC/KBC Package | 128-pin |
| EC Flash / ROM | 256kB Flash ROM |
| Audio Codec | IDT 92HD81 |
| BIOS / SPI Flash | 4MB |
| Charging IC | BQ24745 |
| Charger Architecture | BQ24745 |
| Power IC(s) | ISL62883, TPS51125, TPS51116, TPS51218, ADP3211, APL5930, RT9025 |
| RAM Type | DDRIII 1066 |
| RAM Architecture | 2 Slots (Slot 0, Slot 1) |
| Card Reader IC | Realtek RTS5138 |
| LAN IC | Realtek RTL8111DL |
| WiFi / WLAN IC | 802.11a/b/g/n |
| Thermal Sensor | EMC2102 |
| USB Hub IC | TPS2231R |
| HDMI Level Shifter | SLG8SP585 |
91.4ES01.001
DW40_I/O_BOARD
91.4ET01.001
48.4ET05.0SA
Intel Arrandale
DIS (Discrete)
NPCE781BA0DX
256KB FLASH ROM
BIOS / EC Flash
IDT 92HD81
BQ24745
ADP3211
APL5930
ISL62883
RT9025
TPS51116
TPS51125
TPS51218
DDRIII 1066
RTS5138
RTL8111DL
802.11a/b/g/n
EMC2102
TPS2231R
SLG8SP585
91.4ES01.001
DW40_I/O_BOARD
91.4ET01.001
48.4ET05.0SA
Intel Arrandale
DIS (Discrete)
NPCE781BA0DX
256KB FLASH ROM
BIOS / EC Flash
IDT 92HD81
BQ24745
ADP3211
APL5930
ISL62883
RT9025
TPS51116
TPS51125
TPS51218
DDRIII 1066
RTS5138
RTL8111DL
802.11a/b/g/n
EMC2102
TPS2231R
SLG8SP585
