dell wistron_dv15cp_reva00 schematic
dell=1=wistron_dv15cp_reva00.pdf
This Wistron Corporation Enrico/Caruso 15" UMA schematic, document number A00, dated April 22, 2011, details a motherboard built on the Intel Ibex Peak-M platform with an rPGA988A socket for Arrandale processors. The board number is 48.4IP01.011, revision 10263-1, with project code 91.4IP01.001. The system uses integrated UMA graphics and supports dual-channel DDRIII 1066 memory across two slots. The embedded controller is a Nuvoton NPCE781BA0DXN in a VOTON package, and the audio subsystem is handled by an IDT92HD87B1P codec. Power management is managed by a BQ24707 charger and multiple DC/DC converters including ISL62882, RT8207, RT8237A, TPS51123, TPS51611, and APW7153B. The board features a 4MB SPI flash ROM for BIOS, a Realtek RTS5138 card reader, a Realtek RTL8105E-VC 10/100 NIC, and an 802.11b/g/n with Bluetooth V3.0+HS Mini-Card wireless module.
Q: What is the EC/KBC chip used on this motherboard?
A: The embedded controller is a Nuvoton NPCE781BA0DXN in a VOTON package.
Q: What is the BIOS flash capacity and type?
A: The BIOS is stored on a 4MB SPI flash ROM.
Q: What charging IC is used?
A: The charging controller is a BQ24707 from Maxim.
Q: What are the power management ICs on this board?
A: The power ICs include ISL62882, RT8207, RT8237A, TPS51123, TPS51611, and APW7153B.
| Model | Enrico/Caruso 15" UMA |
| Project Code | 91.4IP01.001 |
| Board Number | 48.4IP01.011 |
| Revision | 10263-1 |
| Date | Friday, April 22, 2011 |
| CPU Platform | Intel Ibex Peak-M / Arrandale |
| CPU Socket | rPGA988A |
| PCH / Southbridge | Intel Ibex Peak-M |
| GPU Type | UMA |
| EC / KBC | NPCE781BA0DXN |
| EC/KBC Package | VOTON |
| Audio Codec | IDT92HD87B1P |
| BIOS / SPI Flash | 4MB Flash ROM |
| BIOS Flash Capacity | 4MB |
| Charging IC | BQ24707 |
| Charger Architecture | MAXIM CHARGER |
| Power IC(s) | ISL62882, RT8207, RT8237A, TPS51123, TPS51611, APW7153B |
| RAM Type | DDRIII |
| RAM Architecture | DDRIII 1066 Channel A, DDRIII 1066 Channel B |
| RAM Quantity / Slots | Slot 0, Slot 1 |
| Card Reader IC | Realtek RTS5138 |
| LAN IC | Realtek RTL8105E-VC |
| WiFi / WLAN IC | 802.11b/g/n BT V3.0+HS Mini-Card |
| Document Number | A00 |
91.4IP01.001
48.4IP01.011
Arrandale
Ibex Peak-M
NPCE781BA0DXN
IDT92HD87B1P
BQ24707
APW7153B
ISL62882
RT8207
RT8237A
TPS51123
TPS51611
DDR3
RTS5138
RTL8105E-VC
n BT V3.0
91.4IP01.001
48.4IP01.011
Arrandale
Ibex Peak-M
NPCE781BA0DXN
IDT92HD87B1P
BQ24707
APW7153B
ISL62882
RT8207
RT8237A
TPS51123
TPS51611
DDR3
RTS5138
RTL8105E-VC
n BT V3.0
