Dell Wistron Jasmine Braswell-M 14061-2 Schematic
This Wistron Rosa_Braswell AIO motherboard, project code 3PD027010001 and PCB number 14061, is built around the Intel Braswell platform with a BGA1170 socket. The board features a discrete AMD Mars-LE GPU and supports DDR3L SODIMM memory. The system EC is a Nuvoton NPCE948L, and the BIOS is stored on an 8MB Winbond W25Q64FW SPI flash. Audio is handled by a Realtek ALC3661 codec paired with a TI TPA3131D2 amplifier. Networking includes a Realtek GbE RTL8111H LAN controller and 802.11 b/g/n WLAN. The charging circuit uses a TI BQ24727RGRR charger IC. Power management is distributed across multiple ICs including NCP81201, RT8243AZQW, RT8237CZQW, APL5930KAI, RT8207MZQW, RT8068AZQW, and ISL62882CHRTZ. The board also integrates a Realtek RTS5170 card reader, a Genesys GL850G-OHY31 USB hub, and a Realtek RTD2136R DP to LVDS converter. The SIO is an ITE IT8739D. The PCB measures 185mm x 230mm with 6 layers.
| Brand | Wistron |
| Model | Rosa_Braswell AIO |
| Motherboard Manufacturer | Wistron Incorporated |
| Project Code | 3PD027010001 |
| Project Name | Jasmine-Intel-Braswell M pAIO |
| Board Number | 14061 |
| Revision | A00 |
| Date | Tuesday, August 02, 2016 |
| CPU Platform | Intel Braswell |
| CPU Socket | BGA1170 |
| GPU Type | AMD Mars-LE |
| EC / KBC | Nuvoton NPCE948L |
| Audio Codec | Realtek ALC3661 |
| BIOS / SPI Flash | Winbond W25Q64FW |
| BIOS Flash Capacity | 8MB |
| Charging IC | TI BQ24727RGRR |
| Power IC(s) | NCP81201, RT8243AZQW, RT8237CZQW, APL5930KAI, RT8207MZQW, RT8068AZQW, ISL62882CHRTZ |
| RAM Type | DDR3L |
| RAM Architecture | SODIMM |
| Card Reader IC | Realtek RTS5170 |
| USB Hub IC | Genesys GL850G-OHY31 |
| LAN IC | Realtek GbE RTL8111H |
| WiFi / WLAN IC | 802.11 b/g/n |
| HDMI Level Shifter | Realtek RTD2136R |
| Audio Amplifier | TI TPA3131D2 |
| SIO | ITE IT8739D |
| PCB Number | 14061 |
| PCB P/N | M6RVR |
| Document Number | A3 |
| Schematic Version | A00 |
| ECO Number | 826155 |
| PCB Board Size | 185mm X 230mm |
| PCB Layers | 6 |
3PD027010001
14061
Braswell
AMD Mars-LE
NPCE948L
ALC3661
W25Q64FW
BIOS / EC Flash
BQ24727RGRR
APL5930KAI
ISL62882CHRTZ
NCP81201
RT8068AZQW
RT8207MZQW
RT8237CZQW
RT8243AZQW
DDR3L
RTS5170
GL850G-OHY31
GBE RTL8111H
RTD2136R
TPA3131D2
Audio Amplifier
IT8739D
Super I/O
3PD027010001
14061
Braswell
AMD Mars-LE
NPCE948L
ALC3661
W25Q64FW
BIOS / EC Flash
BQ24727RGRR
APL5930KAI
ISL62882CHRTZ
NCP81201
RT8068AZQW
RT8207MZQW
RT8237CZQW
RT8243AZQW
DDR3L
RTS5170
GL850G-OHY31
GBE RTL8111H
RTD2136R
TPA3131D2
Audio Amplifier
IT8739D
Super I/O
