RepairDashboard Preview
Ads
The Best Software for Laptop & Computer Repair Shops
Run your computer repair business more efficiently with RepairDashboard. Track tickets, manage inventory, and handle accounting — all from one fast and cloud-based system built for technicians.
Unlock Bios Password DESBLOQUEO BIOS LENOVO L460
Luis Parra
Hola ! Necesito ayuda para desbloquear la contraseña de la bios para Lenovo Thinkpad L460
MB: BL460 NM-A651
  • BIOS ORIGINAL.bin
Salimeh Bolboli
"Instructions for use"
wait 20sec or more.
Enter any ID to hardware Id.
Turn off the computer.
Enjoy.
If 2x 5beep, it's normal.
  • BL460 NM-A651 8MB_PATCHED.BIN
Luis Parra
wait 20sec or more.
Enjoy.
does not give image with this, please edit the one that happens to you with that one if it gives an image
Luis Parra
verifique las instrucciones cuidadosamente
Good morning, follow the steps as the instructions say, the laptop turns on and off after about 10 seconds and it doesn't turn back on, it stays off... I really need to patch the bios that I attached in the first message, with that if it turns on at once
Luis Parra
Friend, it doesn't work, the laptop only turns off once and it stays off, I'll show you a video, instead with the one I'll give you if it turns on...
I do not understand, because it does not give an image... If it is the same bios, only patched. are you sure it's mine? because it has a different name
sometimes problem happen when the file is patched
the name of file does not matter !
i patched it and just named it PATCH !
i checked more and realized that the password is not stored on bios
you need to program EC to remove password
  • NM-A651 EC.bin
Luis Parra
That is to say that I need the programmer for ec? or is that installed in the same bios? since I don't have an EC programmer, only a CH341A bios programmer
