Luis Parra
does not give image with this, please edit the one that happens to you with that one if it gives an image"Instructions for use"
wait 20sec or more.
Enter any ID to hardware Id.
Turn off the computer.
Enjoy.
If 2x 5beep, it's normal.
Good morning, follow the steps as the instructions say, the laptop turns on and off after about 10 seconds and it doesn't turn back on, it stays off... I really need to patch the bios that I attached in the first message, with that if it turns on at onceverifique las instrucciones cuidadosamente
Friend, it doesn't work, the laptop only turns off once and it stays off, I'll show you a video, instead with the one I'll give you if it turns on...
Hola ! Necesito ayuda para desbloquear la contraseña de la bios para Lenovo Thinkpad L460
MB: BL460 NM-A651
i did patch on your fileFriend, it doesn't work, the laptop only turns off once and it stays off, I'll show you a video, instead with the one I'll give you if it turns on...
I do not understand, because it does not give an image... If it is the same bios, only patched. are you sure it's mine? because it has a different namei did patch on your file
last file is yours
sometimes problem happen when the file is patchedI do not understand, because it does not give an image... If it is the same bios, only patched. are you sure it's mine? because it has a different name
And there is no solution for that?sometimes problem happen when the file is patched
the name of file does not matter !
i patched it and just named it PATCH !
I have another laptop the same let me make a backup copy to see if it works with the other laptopthe solution is trying other file
do you need another patched file ?
OKI have another laptop the same let me make a backup copy to see if it works with the other laptop
Attached another bios of another Lenovo l460 laptop that is also blocked
i checked more and realized that the password is not stored on bios
you need to program EC to remove password
you need to program the EC icThat is to say that I need the programmer for ec? or is that installed in the same bios? since I don't have an EC programmer, only a CH341A bios programmer
Luis Parra , Salimeh Bolboli , Vahab Hemmati , banofils , Canaan , Electronica360 , MMONTY123 , user57790 , houssamm , user60406 , afimmorina , e-computers , DanielMuller , moslem402 , gresso , user60172 , amar21atm , Ticha technologies
