Fujitsu Siemens A555 - Quanta FH9 DA0FH9MB6C0 Schematic
The Quanta FH9 motherboard is a Broadwell U platform design documented under revision 2A248, dated November 19, 2014. The system utilizes an Intel Broadwell U processor in a BGA1168 package and supports up to 16GB of DDR3L memory across two SO-DIMM slots. Discrete graphics is provided by an AMD Topaz-S3 XT GPU in a FCBGA631 package with dedicated 256Mx16bit DDR3 VRAM. The embedded controller is an IT8587E/FX, and the audio subsystem is built around an ALC283 codec. Networking is handled by a Realtek RTL8111GS-CG LAN controller and a WLAN/BT combo module on an NGFF2230 interface. The charging architecture is managed by an ISL88732 charger IC, with power delivery supported by TPS51225RUK, G5335, RT8231AGQW, NCP81101B, INTERSIL 62771, and RT8068A regulators. The HDMI interface uses a PS8407A level shifter, and the card reader is controlled by an RTS5227E-GR IC.
Q: What embedded controller is used on the Quanta FH9 motherboard?
A: The embedded controller is an IT8587E/FX.
A: The charging IC is an ISL88732.
Q: What discrete GPU is used on the Quanta FH9?
A: The discrete GPU is an AMD Topaz-S3 XT (64b) in a FCBGA631 package.
A: The audio codec is an ALC283.
Q: What LAN controller is used on the Quanta FH9?
A: The LAN controller is a Realtek RTL8111GS-CG.
| Model | FH9 |
| Project Code | FH9 |
| Document Number | 2A248 |
| Revision | 2A248 |
| Date | Wednesday, November 19, 2014 |
| CPU Platform | Broadwell U |
| GPU Type | AMD Topaz-S3 XT (64b) |
| dGPU Chip Number | AMD Topaz-S3 XT |
| EC / KBC | IT8587E/FX |
| Audio Codec | ALC283 |
| Charging IC | ISL88732 |
| Power IC(s) | TPS51225RUK, G5335, RT8231AGQW, NCP81101B, INTERSIL 62771, RT8068A |
| RAM Type | DDR3L |
| Card Reader IC | RTS5227E-GR |
| LAN IC | RTL8111GS-CG |
| WiFi / WLAN IC | WLAN/BT Combo NGFF2230 |
| HDMI Level Shifter | PS8407A |
