fujitsu siemens amilo a6600 a7600 compal la-1481_rev0.5 schematic
fujitsu siemens amilo a6600 a7600=1=compal la-1481_rev0.5.pdf
This Compal LA-1481 M/B revision 0.5 motherboard, dated 2002-08-12, is designed for the Mobile AMD Athlon XP platform. The core logic is built around the ALI 1535+ southbridge and the ATI MOBILITY-U1 GPU with 596 Graphics embedded. System memory consists of two DDR-SO-DIMM slots supporting DDR 200/266 MHz on a dedicated Memory BUS. The embedded controller is an NS87591L with PS/2 connectivity. The board utilizes a DC/DC Interface for charging and a Power Circuit DC/DC for power regulation. Networking is provided by a Realtek RTL 8100BL LAN controller, with wireless connectivity via a Mini PCI port. The BIOS is stored in a standard BIOS flash, and the audio subsystem uses an AC-LINK codec. Additional I/O includes a CardBus Controller, USB ports, and a Thermal Sensor for monitoring.
A: The board number is LA-1481 M/B, revision 0.5.
A: The EC/KBC is an NS87591L with PS/2 connectivity.
A: It supports DDR memory via two DDR-SO-DIMM slots.
A: The LAN controller is a Realtek RTL 8100BL.
| Model | LA-1481 M/B |
| Board Number | LA-1481 M/B |
| Revision | 0.5 |
| Date | 2002-08-12 |
| CPU Platform | Mobile AMD Athlon XP |
| PCH / Southbridge | ALI 1535+ |
| GPU Type | ATI MOBILITY-U1 |
| Graphics Architecture | 596 Graphics embedded |
| EC / KBC | NS87591L |
| EC/KBC Package | PS/2 conn |
| Audio Codec | AC-LINK |
| BIOS / SPI Flash | BIOS |
| Charging IC | DC/DC Interface |
| Power IC(s) | Power Circuit DC/DC |
| RAM Type | DDR |
| RAM Architecture | Memory BUS(DDR) |
| RAM Quantity / Slots | DDR-SO-DIMM X2 |
| LAN IC | RTL 8100BL |
| WiFi / WLAN IC | Mini PCI port |
| Card Reader IC | CardBus Controller |
| USB Hub IC | USB |
| Thermal Sensor | Thermal Sensor |
