fujitsu siemens esprimo v5535 inventec z17m 1.0 6050a2186801 1
This Inventec Corporation motherboard, project code xxxx (FSC_v5535) revision A02 dated June 15, 2007, is built around the Intel Yonath Processor platform. The system architecture features a SiS 672MX Northbridge with integrated SiS Mirage 3 GUI 2D/3D Graphics and a SiS 968 Southbridge. Memory is supported via a single DDR2-667 channel. The embedded controller is an ITE IT8512 in a 64-pin LQFP package. System firmware is stored on an SPI 8M ROM. Audio is handled by an ALC268 codec, and networking by a SiS 196 LAN PHY. Power management includes a MAX8770 charging IC and a TPS51117 DDR power IC. Thermal monitoring is provided by an ADM1032A sensor. The clock generator is an ICS9LPR600D. Wireless connectivity is supported via a Mini Card (WLAN) slot.
A: The embedded controller is an ITE IT8512 in a 64-pin LQFP package.
Q: What is the BIOS flash configuration?
A: The system uses an SPI 8M ROM for firmware storage.
A: The motherboard supports a single DDR2-667 channel.
Q: What charging IC is used?
A: The charging IC is a MAX8770.
| Brand | Inventec Corporation |
| Motherboard Manufacturer | Inventec Corporation |
| Project Code | xxxx (FSC_v5535) |
| Board Number | Mother Board |
| Revision | A02 |
| Date | Friday, June 15, 2007 |
| CPU Platform | Intel Yonath Processor |
| EC / KBC | ITE IT8512 |
| EC/KBC Package | 64 pin LQFP |
| Audio Codec | ALC268 |
| BIOS / SPI Flash | SPI 8M ROM |
| Charging IC | MAX8770 |
| Power IC(s) | TPS51117 |
| RAM Type | DDR2 667 |
| RAM Architecture | Single DDR2-667 Channel |
| Thermal Sensor | ADM1032A |
| LAN IC | SiS 196 |
| WiFi / WLAN IC | Mini Card (WLAN) |
| Clock Generator | ICS9LPR600D |
| GPU Type | SiS Mirage 3 GUI 2D/3D Graphic |
| Graphics Architecture | Integrated SiS Mirage 3 GUI 2D/3D Graphic |
| PCH / Southbridge | SiS 968 |
| Northbridge | SiS 672MX |
FSC_V5535
Project Code
Yonath
IT8512
ALC268
MAX8770
Charging / PD IC
TPS51117
Power IC
DDR2
ADM1032A
Thermal / Fan Control
196
LAN Controller
ICS9LPR600D
Clock Generator
3D
Graphics
Graphic
Graphics
Mirage 3 GUI 2D
Graphics
Graphics
968
PCH / Southbridge
672MX
Northbridge / MCH
FSC_V5535
Project Code
Yonath
IT8512
ALC268
MAX8770
Charging / PD IC
TPS51117
Power IC
DDR2
ADM1032A
196
LAN Controller
ICS9LPR600D
Clock Generator
3D
Graphics
Graphic
Graphics
Mirage 3 GUI 2D
Graphics
Graphics
968
PCH / Southbridge
672MX
Northbridge / MCH
