gateway nv55c ls-6583p rev1.0 odd 1
This Compal Electronics, Inc. document is an ODD Extend Board schematic, designated as model PEW71/81 ODD/B with PCB name LS-6583P ODD/B at revision 1.0, dated July 8, 2010. The document number is DA40000UT10, and the project code covers a broad range of PEW71/81/91/72/82/92/76/86/96 platforms. The board features an ODD connector JODD2 (Santa 206401-1_RV) and an FPC connector JP1 (FPC_R0P65X5-P1_12P) for interfacing with the mainboard via an FFC Hot-Bar 2A connection. Power delivery includes +5VS rails with local decoupling capacitors C414 (10uF), C416 (1uF), and C418 (1000pF). The board is classified as Compal Secret Data.
Q: What is the document number for this Compal ODD Extend Board?
A: The document number is DA40000UT10.
Q: What is the PCB name and revision for this board?
A: The PCB name is LS-6583P ODD/B at revision 1.0.
Q: What ODD connector is used on this board?
A: The ODD connector is JODD2, model Santa 206401-1_RV.
| Model Name | PEW71/81 ODD/B |
| Board Number | LS-6583P ODD/B |
| Date | 2010/07/08 |
| Document Number | DA40000UT10 |
| Project Code | PEW71/81/91/72/82/92/76/86/96 |
