Schematic gigabyte ga-965p-ds3 ver 3.3 schematic
BrandGigabyte
Model965P-DS3
Motherboard ManufacturerGigabyte Technology
Revision3.3
Date星期四, 三月 01, 2007
CPU PlatformIntel Pentium 4 LGA775
PCH / SouthbridgeICH8
GPU TypeGMCH BROADWATER
EC / KBCITE ITE8712GB-IX
Audio CodecALC883
BIOS / SPI FlashWinbond 8M Flash
Charging ICISL6312
Power IC(s)ISL6537, LTSM104, LD1084, 6601
RAM TypeDDRII
RAM ArchitectureDual Channel (Channel A, Channel B)
RAM Quantity / Slots4 DIMMs (2 per channel)
LAN ICMarvell 88E8053
WiFi / WLAN ICNot explicitly present in source
Card Reader ICITE IT8212
The Gigabyte 965P-DS3 is a Revision 3.3 motherboard designed by Gigabyte Technology, dated March 1, 2007. It is built around the Intel Pentium 4 LGA775 CPU platform with a GMCH BROADWATER integrated GPU and an ICH8 southbridge. The board supports dual-channel DDRII memory across four DIMM slots, two per channel. The embedded controller is an ITE ITE8712GB-IX. Audio is handled by an ALC883 codec, while networking is provided by a Marvell 88E8053 LAN IC. Storage expansion includes an ITE IT8212 IDE RAID controller. The BIOS is stored on a Winbond 8M Flash SPI ROM. Power management is managed by an ISL6312 PWM controller, supported by ISL6537, LTSM104, LD1084, and 6601 power ICs.
A: The board uses a Winbond 8M Flash SPI BIOS ROM.
A: The embedded controller is an ITE ITE8712GB-IX.
A: The board supports dual-channel DDRII memory with four DIMM slots, configured as two slots per channel (Channel A and Channel B).
A: The board uses a Marvell 88E8053 LAN IC.
A: The board uses an ALC883 audio codec.
  • Gigabyte=GA-965P-DS3 Ver 3.3.pdf
