Gigabyte GA-B150M-SE-SI Rev 10 Schematic
The Gigabyte GA-B150M-SC-SI motherboard, revision 1.1, dated April 21, 2016, is built on the Intel LGA1151 platform with a B150 PCH. It features dual memory architecture supporting both DDR4 and DDRIII, with two DDR4 DIMM slots. The system is managed by an ITE8628 EC/KBC, and audio is handled by a Realtek ALC887 codec. Networking is provided by a Realtek 8111G LAN IC and a Realtek 8111HS WiFi/WLAN IC. The board utilizes a 64M SPI BIOS flash. Power regulation is managed by ISL95858_856 PWM and MOSFET stages for VCORE and VCCGT, alongside RT8237 and NCP3933 voltage regulation components. Display output includes an RTD2168 DP to VGA converter and HDMI support. The IT8892 controller manages card reader and USB hub functions.
A: The ITE8628 is used as the EC/KBC.
Q: What is the BIOS flash capacity?
A: The BIOS flash is a 64M SPI BIOS.
Q: What memory types does this board support?
A: The board supports both DDR4 and DDRIII memory, with two DDR4 DIMM slots.
Q: What LAN and WiFi ICs are present?
A: The LAN IC is a Realtek 8111G, and the WiFi/WLAN IC is a Realtek 8111HS.
The Gigabyte GA-B150M-SE-SI revision 1.0 motherboard is built on the Intel LGA1151 Skylake platform with a B150 PCH. It features dual-channel DDR4 memory architecture with two DIMM slots. The board utilizes an ITE 8628 EC/KBC and a Realtek ALC887 audio codec. Networking is handled by a Realtek RTL8111G LAN IC. The SPI Dual BIOS configuration supports 64M flash. Display output includes DP to VGA conversion via the RTD2168 IC.
Q: What is the EC/KBC model used on this motherboard?
A: The EC/KBC is an ITE 8628.
A: The board uses a SPI Dual BIOS configuration with 64M capacity.
Q: What audio codec is used?
A: The audio codec is a Realtek ALC887.
Q: What LAN controller is used?
A: The LAN controller is a Realtek RTL8111G.
| Brand | Gigabyte Technology |
| Model | GA-B150M-SC-SI |
| Motherboard Manufacturer | Gigabyte Technology |
| Board Number | GA-B150M-SC-SI |
| Revision | 1.1 |
| Date | Thursday, April 21, 2016 |
| CPU Platform | Intel LGA1151 |
| CPU Socket | LGA1151 |
| PCH / Southbridge | b150/"]PCH (B150)[/URL] |
| EC / KBC | ITE8628 |
| Audio Codec | Realtek ALC887 |
| BIOS / SPI Flash | SPI BIOS (64M) |
| BIOS Flash Capacity | 64M |
| RAM Type | ddr4-ddriii/"]DDR4, DDRIII[/URL] |
| RAM Architecture | DDR4 DIMM X 1, DDR4 DIMM X 1, DDRIII BUS |
| RAM Quantity / Slots | DDR4 DIMM X 1, DDR4 DIMM X 1 |
| LAN IC | Realtek 8111G |
| WiFi / WLAN IC | Realtek 8111HS |
| HDMI Level Shifter | rtd2168-dp-to-vga-ic/"]RTD2168 - DP to VGA - IC[/URL], RTD2168 - DP to VGA - Conn |
| Card Reader IC | IT8892 |
| USB Hub IC | IT8892 |
| Charging IC | ISL95858_856 PWM |
| Power IC(s) | ISL95858_856 MOS_VCORE, ISL95858_856 MOS_VCCGT, RT8237_DDR_BEAD, RT8237_PCH-BEAD, NCP3933 OVER VOLTAGE |
| GPU Type | PCI EXPRESS X16 |
| Graphics Architecture | PCIe-1 gen3 |
| Document Number | Custom |
| Model | GA-B150M-SE-SI |
| Board Number | GA-B150M-SE-SI |
| Date | Wednesday, May 25, 2016 |
| CPU Platform | [URL="https://dr-bios.com/components/cpu-platform/intel-lga1151/"]Intel LGA1151 (Skylake)[/URL] |
| PCH / Southbridge | B150 |
| EC / KBC | ITE 8628 |
| BIOS / SPI Flash | SPI Dual BIOS (64M) |
| LAN IC | Realtek RTL8111G |
| RAM Type | DDR4 |
| RAM Architecture | DDR4 DIMM X 1, DDR4 DIMM X 1 |
| HDMI Level Shifter | RTD2168 |
GA-B150M-SC-SI
Intel LGA1151
PCH (B150)
ITE8628
ALC887
DDR4 / DDRIII
8111G
Realtek 8111HS
RTD2168 - DP TO VGA - CONN
RTD2168 - DP TO VGA - IC
IT8892
IT8892
ISL95858_856 PWM
RT8237_DDR_BEAD
RT8237_PCH-BEAD
PCI Express X16
PCIe-1 gen3
GA-B150M-SE-SI
B150
8628
RTL8111G
DDR4
RTD2168
GA-B150M-SC-SI
Intel LGA1151
PCH (B150)
ITE8628
ALC887
DDR4 / DDRIII
8111G
Realtek 8111HS
IT8892
IT8892
ISL95858_856 PWM
RT8237_DDR_BEAD
RT8237_PCH-BEAD
PCI Express X16
PCIe-1 gen3
GA-B150M-SE-SI
B150
8628
RTL8111G
DDR4
RTD2168
