Gigabyte GA-X99-SOC Force-LN2 Rev 1.0 1.02 Schematic
The Gigabyte GA-X99-SOC Force-LN2 motherboard, revision 1.02, dated December 12, 2014, is built around the Intel LGA2084 CPU platform with a PCH southbridge. It features a dual BIOS configuration and supports DDR4 memory across four DIMM slots in a quad-channel architecture (Channels A, B, C, D
| Brand | Gigabyte Technology |
| Model | GA-X99-SOC Force-LN2 |
| Motherboard Manufacturer | Gigabyte Technology |
| Board Number | GA-X99-SOC Force-LN2 |
| Revision | 1.02 |
| Date | Friday, December 12, 2014 |
| CPU Platform | INTEL LGA2084 |
| PCH / Southbridge | PCH |
| EC / KBC | IT8791 |
| EC / KBC | IT8951 |
| Audio Codec | ALC1150 |
| BIOS / SPI Flash | DUAL BIOS |
| Charging IC | IR3580 |
| Charging IC | IR3570 |
| Power IC(s) | IR3580 |
| Power IC(s) | IR3570 |
| Power IC(s) | IR3553 |
| RAM Type | DDR 4 |
| RAM Architecture | Quad Channel (A, B, C, D) |
| RAM Quantity / Slots | 4 DIMM |
| LAN IC | INTEL 1Gb LAN |
| WiFi / WLAN IC | INTEL I217 |
| USB Hub IC | RENESAS uPD720210_A |
| USB Hub IC | RENESAS uPD720210_B |
| Card Reader IC | HS5253 |
| Thermal Sensor | ADS1118 |
| Super I/O | ITE8620 |
| VR Controller | IR3580 |
| VR Controller | IR3570 |
| VR Controller | IR3553 |
| EC Fan Controller | IT8791 |
| EC Fan Controller | IT8951 |
| PCIE Clock Buffer | PCIE CLK BUFFER |
| CPU Clock Buffer | CPU CLK BUFFER |
| HDMI Level Shifter | AL1150 |
| Audio Amplifier | AL1150 |
| M.2 Slot | M2 SLOT |
| SATA Controller | SATA3 X6 |
| SAS Controller | SAS SATA3 X4 |
| USB 3.0 Controller | RENESAS uPD720210_A |
| USB 3.0 Controller | RENESAS uPD720210_B |
| PCI Express Switch | SW |
| PCI Express Switch | PCIE X16_X8 SWITCH |
| Document Number | GA-X99-SOC Force-LN2 |
GA-X99-SOC FORCE-LN2
INTEL LGA2084
PCH
IT8791
IT8951
ALC1150
IR3580
IR3570
IR3580
IR3570
IR3553
DDR-4
1GB LAN
Intel I217
UPD720210_A
UPD720210_B
HS5253
ADS1118
ITE8620
Super I/O
AL1150
INTEL LGA2084
PCH
IT8791
IT8951
ALC1150
IR3580
IR3570
IR3580
IR3570
IR3553
DDR-4
1GB LAN
Intel I217
UPD720210_A
UPD720210_B
HS5253
ADS1118
ITE8620
Super I/O
AL1150
