Gigabyte H410M DS2V V2 Schematic
The Gigabyte H410M DS2V V2 motherboard, revision 1.01, is built around the Intel LGA1200 (Comet Lake) platform with an H410 PCH. Audio is handled by a Realtek ALC897 VA2 codec, while the ITE 8688 EC/KBC manages LPC I/O. The system utilizes a single SPI BIOS flash with a capacity of 128Mb. Networking is provided by a Realtek RTL8125BS (I219V) LAN IC. Power regulation includes an ISL95866C PWM controller for Vcore, alongside RT8237 and RT8068 regulators for DDR_VDDQ, PCH_VCC1_05, and VPP rails. The board supports two DDR4 DIMM slots and features an RTD2168 DP to VGA converter for display output.
A: The board number is 9MH41MS2H-00-11B, and the project code is U19148-0.
A: The motherboard uses a single SPI BIOS flash with a capacity of 128Mb.
A: The motherboard uses an ITE 8688 LPC I/O controller as the EC/KBC.
A: The audio codec is a Realtek ALC897 VA2.
A: The LAN controller is a Realtek RTL8125BS (I219V).
| Brand | Gigabyte Technology |
| Model | H410M DS2V V2 |
| Motherboard Manufacturer | Gigabyte Technology |
| Project Code | U19148-0 |
| Board Number | 9MH41MS2H-00-11B |
| Revision | 1.01 |
| Date | Wednesday, January 20, 2021 |
| CPU Platform | Intel LGA1200 (Comet Lake) |
| PCH / Southbridge | H410 |
| Audio Codec | Realtek ALC897 VA2 |
| EC / KBC | ITE 8688 |
| BIOS / SPI Flash | SPI BIOS (128Mb) |
| LAN IC | Realtek RTL8125BS (I219V) |
| Charging IC | ISL95866C PWM |
| Power IC(s) | RT8237_DDR_VDDQ, RT8237_PCH_VCC1_05_PCH, RT8068_VPP |
| RAM Type | DDR4 |
| RAM Architecture | DDR4 DIMM X 2 |
| RAM Quantity / Slots | 2 |
| HDMI Level Shifter | RTD2168 - DP to VGA |
U19148-0
Project Code
9MH41MS2H-00-11B
Board Number
H410
PCH / Southbridge
ALC897-VA2
8688
RTL8125BS (I219V)
LAN Controller
ISL95866C PWM
Charging / PD IC
RT8068_VPP
Power IC
RT8237_DDR_VDDQ
Power IC
Power IC
DDR4
RTD2168 - DP TO VGA
Signal Conditioning IC
U19148-0
Project Code
9MH41MS2H-00-11B
Board Number
H410
PCH / Southbridge
ALC897-VA2
8688
RTL8125BS (I219V)
LAN Controller
ISL95866C PWM
Charging / PD IC
RT8068_VPP
Power IC
RT8237_DDR_VDDQ
Power IC
Power IC
DDR4
RTD2168 - DP TO VGA
