Schematic Gigabyte X570 AORUS ULTRA Rev 1.0 1.01 1.1 1.02 1.11 Schematic
BrandGigabyte
ModelX570 AORUS ULTRA
Document NumberU98126-0
Revision1.0
DateWednesday, April 03, 2019
CPU PlatformAMD X570
Audio Codecalc1220-vb2-codec/"]ALC1220-VB2 CODEC[/URL]
LAN ICINTEL WGI211AT
EC / KBCIT8795
Super I/OIT8688E
USB Hub ICGL850S
RedriverPI3EQX1002B1ZLE
MCUIT8297
PWM ControllerIR35201
The Gigabyte X570 AORUS ULTRA motherboard, documented under Document Number U98126-0 Revision 1.0 dated April 3, 2019, is built on the AMD X570 platform. The board utilizes an IT8795 EC/KBC and an IT8688E Super I/O for system management. Audio is handled by the ALC1220-VB2 CODEC, while networking is provided by an Intel WGI211AT LAN IC. The design incorporates a GL850S USB 2.0 hub controller and a PI3EQX1002B1ZLE redriver for signal integrity. An IT8297 MCU is present for additional control functions, and the VRM is managed by an IR35201 PWM controller.
Q: What EC/KBC is used on the Gigabyte X570 AORUS ULTRA?
A: The motherboard uses an IT8795 EC/KBC.
A: The audio codec is the ALC1220-VB2 CODEC.
Q: What LAN controller is used on the X570 AORUS ULTRA?
A: The board features an Intel WGI211AT LAN IC.
BrandGigabyte
Document NumberU98126-02
Revision1.01
DateWednesday, June 05, 2019
EC / KBCIT8795
EC / KBCIT8688E
EC / KBCIT8297
USB Hub ICGL850
Charging ICMCU IT8297
The Gigabyte X570 AORUS ULTRA motherboard, documented under Document Number U98126-02 Revision 1.01 dated June 5, 2019, is built on the AMD X570 platform. The board utilizes an ALC1220-VB2 audio codec and an Intel WGI211AT LAN controller. Multiple embedded controllers are employed, including the IT8795, IT8688E, and IT8297, with the IT8297 also serving as the charging MCU. A GL850 USB hub IC and a PI3EQX1002B1ZLE redriver are present for USB connectivity. The schematic revision history indicates a transition from a dual BIOS configuration to a single BIOS setup via resistor changes (OR56 to OR58).
Q: What embedded controllers are used on the X570 AORUS ULTRA?
A: The board uses three embedded controllers: IT8795, IT8688E, and IT8297.
Q: What is the audio codec on this motherboard?
A: The audio codec is the ALC1220-VB2.
A: The LAN controller is the Intel WGI211AT.
Q: Does this board support a single or dual BIOS configuration?
A: The schematic revision history notes a change to a single BIOS configuration by changing OR56 to OR58.
BrandGigabyte
Motherboard ManufacturerGigabyte
Project CodeU98126-02
Board NumberU98126-02
Revision1.02
DateMonday, July 22, 2019
PCH / SouthbridgeX570
EC / KBCIT8795
WiFi / WLAN ICIntel 9260
USB Hub ICGL850
Super I/OIT8688E
MCUIT8297
Charging ICRTS5441
Charging ICRTS5441E
Power IC(s)IR35201
RAM TypeDDR4
RAM ArchitectureDual Channel
RAM Quantity / Slots4
Card Reader ICRTS5441
Card Reader ICRTS5441E
HDMI Level ShifterHDMI
USB-C ControllerR_TYPEC
Thermal SensorH/W MONITOR
The Gigabyte X570 AORUS ULTRA motherboard, revision 1.02, is built on the AMD X570 platform with a project code of U98126-02. The board utilizes an IT8795 EC/KBC and an IT8688E Super I/O for system management. Audio is handled by the ALC1220-VB2 CODEC, while networking is provided by an Intel WGI211AT LAN IC and an Intel 9260 WiFi module. The system supports dual-channel DDR4 memory across four slots. Power management is governed by an IR35201 PWM controller. The board features a GL850 USB hub IC, a PI3EQX1002B1ZLE redriver, and an IT8297 MCU. For USB-C and card reader functionality, it employs RTS5441 and RTS5441E controllers. The HDMI interface is present for video output.
A: The motherboard uses an ALC1220-VB2 CODEC.
Q: What LAN and WiFi ICs are used on this motherboard?
A: The motherboard uses an Intel WGI211AT LAN IC and an Intel 9260 WiFi module.
Q: What USB hub and redriver ICs are present?
A: The motherboard includes a GL850 USB hub IC and a PI3EQX1002B1ZLE redriver.
Q: What card reader and USB-C controllers are used?
A: The motherboard uses RTS5441 and RTS5441E controllers for card reader and USB-C functionality.
BrandGigabyte
Board Number1011
Revision1.1
DateMonday, September 16, 2019
EC / KBCIT8795
Audio CodecALC1220-VB2
Charging ICIR35201
Power IC(s)IR35201
LAN ICIntel WGI211AT
USB Hub ICGL850S
HDMI Level ShifterPI3EQX1002B1ZLE
Thermal SensorIT8688E
The Gigabyte X570 AORUS ULTRA motherboard, project code U98126-02, revision 1.1, is built on the AMD X570 platform. The board number is 1011, with a schematic date of Monday, September 16, 2019. The system is managed by an IT8795 EC/KBC, while audio processing is handled by the ALC1220-VB2 codec. Power regulation is managed by an IR35201 controller. Networking is provided by an Intel WGI211AT LAN IC and an Intel 9260 WiFi module. The board features a GL850S USB hub controller and an RTS5441 card reader IC. HDMI signal conditioning is performed by a PI3EQX1002B1ZLE redriver, and thermal monitoring is handled by an IT8688E sensor.
Q: What audio codec is present on this motherboard?
A: The audio codec is an ALC1220-VB2.
Q: What LAN and WiFi controllers are used?
A: The LAN controller is an Intel WGI211AT, and the WiFi module is an Intel 9260.
Q: What USB hub and card reader controllers are present?
A: The USB hub controller is a GL850S, and the card reader controller is an RTS5441.
BrandGigabyte
Revision1.11
DateTuesday, February 18, 2020
EC / KBCIT8795
Super I/OIT8688E
MCUIT8297
USB Hub ICGL850S
The Gigabyte X570 AORUS ULTRA motherboard, document number U98126-02 revision 1.11 dated February 18, 2020, is built on the AMD X570 platform. The audio subsystem is driven by an ALC1220-VB2 CODEC. Networking is handled by an Intel WGI211AT LAN IC. The embedded controller is an IT8795, with an IT8688E Super I/O and an IT8297 MCU for additional management. A GL850S USB hub IC and a PI3EQX1002B1ZLE redriver are present for USB connectivity. The voltage regulation is managed by an IR35201 PWM controller. The board supports a single BIOS configuration, as indicated by revision history notes to set single BIOS via OR56 to OR58 1K/4/1.
Q: What is the board number and revision for this Gigabyte X570 AORUS ULTRA?
A: The document number is U98126-02, revision 1.11, dated February 18, 2020.
A: The embedded controller is an IT8795, with an IT8688E Super I/O and an IT8297 MCU.
Q: What audio codec and LAN IC are present?
A: The audio codec is an ALC1220-VB2 CODEC, and the LAN IC is an Intel WGI211AT.
Q: Does this motherboard support a single BIOS configuration?
A: Yes, revision history indicates a change to set single BIOS by changing OR56 to OR58 1K/4/1.
  • Gigabyte X570 AORUS ULTRA Rev 1.0 Schematic.pdf
  • Gigabyte X570 AORUS ULTRA Rev 1.01 Schematic.pdf
  • Gigabyte X570 AORUS ULTRA Rev 1.1 Schematic.pdf
  • Gigabyte X570 AORUS ULTRA Rev 1.02 Schematic.pdf
  • Gigabyte X570 AORUS ULTRA Rev 1.11 Schematic.pdf
