hasee hp500 hp520 quanta sw7_rev1a schematic
hasee hp500 hp520=1=quanta sw7_rev1a.pdf
The Quanta SW7 project motherboard is built around an Intel Merom 479P (uPGA)/46W CPU platform with a Crestline Northbridge and ICH-8M Southbridge. System clock generation is handled by an ICS9LPRS365AGLFT clock generator at reference designator U24, driven by a 14.318MHz crystal at Y9. The embedded controller is a KB3926. Power management includes a MAX8778 system power IC, a MAX8771 CPU core regulator, a MAX1992 VGA core regulator, a MAX8724 system charger, a TPS51116REGR DDR_VTERM regulator, and a MAX8717 for VCCP +1.5V and GMCH 1.05V. Memory configuration supports two DDR2-SODIMM slots running at 533/667 MHz. Networking is provided by a Marvell 8055/8039 LAN IC, and a PCI7402 controller manages the card reader interface.
Q: What is the project code and board manufacturer for this motherboard?
A: The project code is SW7, manufactured by Quanta Computer Inc.
A: The embedded controller is a KB3926.
Q: What is the clock generator IC and its reference designator?
A: The clock generator is an ICS9LPRS365AGLFT at reference designator U24.
A: The system charger IC is a MAX8724.
A: The LAN IC is a Marvell 8055/8039.
| Project Code | SW7 |
| Date | Friday, September 28, 2007 |
| CPU Platform | Merom 479P (uPGA)/46W |
| Northbridge | Crestline |
| Southbridge | ICH-8M |
| Clock Generator | ICS9LPRS365AGLFT |
| Clock Generator Reference Designator | U24 |
| EC / KBC | KB3926 |
| Charging IC | MAX8724 |
| System Power IC | MAX8778 |
| CPU Core Power IC | MAX8771 |
| VGA Core Power IC | MAX1992 |
| DDR_VTERM Regulator | TPS51116REGR |
| VCCP +1.5V and GMCH 1.05V Power IC | MAX8717 |
| LAN IC | MARVELL 8055/8039 |
| Card Reader IC | PCI7402 |
| RAM Type | DDR II |
| RAM Architecture | 533/667 MHz DDR II |
| RAM Quantity / Slots | DDR2-SODIMM1, DDR2-SODIMM2 |
| Crystal Frequency (Clock Gen) | 14.318MHz |
| Crystal Reference Designator (Clock Gen) | Y9 |
