So far, we've taught you two ways to fix problems with ME Region. In this article we are going to tell you another problem solving way with all new software.Well, this new software is called Intel TXE/ME Injector. Working with this software is very easy, you just introduce the BIOS and ME Region file and you will get new and cleared one. easy peasy lemon squeezy
Let's move forward step by step:
When you execute this software for the first time you will face with this message :
This means you should choose a folder which contains a file or a database of different versions of ME Region.
(In previous articles, we described how to identify ME Region version by using calculator also ME Analyzer and UEFItool softwares.)
Well, after you select the ME Region folder, this window will shows up :
As its obvious as you see, you should click on "open bios" button.
As you see, the red box shows ME Region information of selected bios and the green box shows the right ME region that need to be replaced in BIOS file (if you give multiple me region files you can change selected file from here. For the record this software lists close version of me region files in this part). At the end select " Save New Bios " and choose wherever you want to save new file. thats all
Notice : This software supports only ME Regions up to version 10.
Intel TXE/ME Injector Software: ( Attached )
New Software Updates Version 1.0.0.2 : ( Attached )
Password : dr-bios.com
Tutorial Video: ( Attached )
I hope this article will be useful for you
