HP 15 EPV51 LA-G078P Schematic
This Compal EPT51 reference design, documented as PCB number LA-G078P revision 0.3 dated January 5, 2018, is built around the AMD Stoney Ridge (FT4) processor platform. The discrete graphics subsystem utilizes an AMD R17M-M1-30/70 GPU with GDDR5 X2 or GDDR5 X4 VRAM configurations. System memory consists of two DDR4-DIMM slots operating in single-channel mode at 1866 MHz. The embedded controller is a KB9022, and the system BIOS is stored on an 8M SPI ROM. Audio is handled by an ALC3227 codec, while wired networking is provided by an RTL8111HSH-CG Gigabit Ethernet controller. A G753T11U thermal sensor monitors system temperatures, and an SLB 9665 TPM module is present for security. The design also includes an AK6485RB card reader, an AM1153 USB to SATA bridge, and a PI3PCIE3212 multiplexer for PCIe lane switching.
A: The embedded controller is a KB9022.
A: The system uses an 8M SPI ROM for BIOS storage.
Q: What is the graphics configuration?
A: The discrete GPU is an AMD R17M-M1-30/70 with GDDR5 X2 or GDDR5 X4 VRAM.
A: The board supports two DDR4-DIMM slots in single-channel configuration at 1866 MHz.
| Project Code | EPT51 |
| Board Number | LA-G078P |
| Revision | 0.3 |
| Date | 2018/01/05 |
| CPU Platform | AMD Stoney Ridge (FT4) |
| GPU Type | AMD R17M-M1-30/70 |
| Graphics Architecture | GDDR5 X2 / GDDR5 X4 |
| EC / KBC | KB9022 |
| Audio Codec | ALC3227 |
| BIOS / SPI Flash | 8M SPI ROM |
| LAN IC | RTL8111HSH-CG |
| Card Reader IC | AK6485RB |
| Thermal Sensor | G753T11U |
| RAM Type | DDR4-DIMM x 2 |
| RAM Architecture | Single Channel |
| TPM | SLB 9665 |
| USB to SATA Transmitter | AM1153 |
| Mux | PI3PCIE3212 |
EPT51
LA-G078P
AMD R17M-M1-30/70
GDDR5 X2 / GDDR5 X4
KB9022
ALC3227
RTL8111HSH-CG
AK6485RB
G753T11U
DDR4-DIMM X 2
PI3PCIE3212
EPT51
LA-G078P
AMD R17M-M1-30/70
GDDR5 X2 / GDDR5 X4
KB9022
ALC3227
RTL8111HSH-CG
AK6485RB
G753T11U
DDR4-DIMM X 2
PI3PCIE3212
