hp 540 quanta_ql6_rev2a schematic
hp 540=1=quanta_ql6_rev2a.pdf
The Quanta QL6 NB5 motherboard revision 2A, dated February 26, 2008, is built around the Intel Penryn 478P (uPGA)/35W CPU platform with a Cantiga Northbridge and ICH9-M Southbridge. Graphics are handled by an NVIDIA NB9M-64bit GPU. The system uses an ENE KBC for embedded controller functions and a Realtek ALC268 audio codec. The BIOS is stored on SPI flash. Power management is handled by an ISL6251AHAZ-T system charger, ISL6237IRZ-T system power IC, ISL6266A CPU core regulator, Oz8118 GPU core regulator, TPS51116REGR for DDR_VTERM, and RT8204 for VCCP +1.5V and GMCH 1.05V. Memory configuration consists of two DDRII SODIMM slots supporting DDRII 667/800 MHz. Networking is provided by a Realtek RTL8102E/8111C LAN IC and an Atheros AR5B355B MLF64PIN wireless module. Clock generation is managed by an ICS 9LPRS355BKLF and RTM875N-606-VD-GR clock generator.
Q: What is the project code and board number for this motherboard?
A: The project code is QL6 and the board number is NB5, revision 2A.
A: The embedded controller is an ENE KBC.
| Brand | Quanta |
| Project Code | QL6 |
| Board Number | NB5 |
| Revision | 2A |
| Date | Tuesday, February 26, 2008 |
| CPU Platform | Penryn 478P (uPGA)/35W |
| Northbridge | Cantiga |
| Southbridge | ICH9-M |
| GPU Type | NVIDIA NB9M-64bit |
| EC / KBC | ENE KBC |
| Audio Codec | Realtek ALC268 |
| BIOS / SPI Flash | SPI |
| Charging IC | ISL6251AHAZ-T |
| Power IC(s) | ISL6237IRZ-T, Oz8118, ISL6266A, TPS51116REGR, RT8204 |
| RAM Type | DDRII |
| RAM Architecture | DDRII 667/800 MHz |
| LAN IC | RTL8102E/8111C |
| WiFi / WLAN IC | AR5B355B MLF64PIN |
| Clock Generator | ICS 9LPRS355BKLF, RTM875N-606-VD-GR |
| Audio Amplifier | TPA6017A2 |
| System Power | ISL6237IRZ-T |
| CPU Core | ISL6266A |
| System Charger | ISL6251AHAZ-T |
| DDR_VTERM | TPS51116REGR |
| VCCP +1.5V AND GMCH 1.05V | RT8204 |
| GPU Core | Oz8118 |
QL6
NB5
Penryn
ICH9
NB9M-64bit
ALC268
ISL6251AHAZ-T
ISL6237IRZ-T
ISL6266A
OZ8118
RT8204
TPS51116REGR
DDR2
RTL8102E/8111C
AR5B355B MLF64PIN
ICS 9LPRS355BKLF
Clock Generator
RTM875N-606-VD-GR
Clock Generator
TPA6017A2
Audio Amplifier
QL6
NB5
Penryn
ICH9
NB9M-64bit
ALC268
ISL6251AHAZ-T
ISL6237IRZ-T
ISL6266A
OZ8118
RT8204
TPS51116REGR
DDR2
RTL8102E/8111C
AR5B355B MLF64PIN
ICS 9LPRS355BKLF
Clock Generator
RTM875N-606-VD-GR
Clock Generator
TPA6017A2
Audio Amplifier
