hp 6220 ap10-6050a0066801 u40ii1 mb nl rc 1207 1
The Elitegroup U40II1 Rev C motherboard, dated December 7, 2007, is built around the Intel Merom CPU platform with a Socket 478 interface, paired with the Intel Crestline North Bridge and ICH8-M Southbridge. Graphics are integrated via the Crestline IGP. The system uses DDR2 SODIMM memory in a single slot configuration. The embedded controller is an ITE IT8512E, and the audio codec is a Realtek ALC662. The SPI flash ROM stores the BIOS. Power management is handled by a combination of ICs including the ISL6261 for CPU core voltage, OZ827 for GFX core, and APM2556 for charging from either battery or adaptor. The LAN controller is a Realtek RTL8101E, and the card reader is controlled by an RTS5158. The clock generator is an ICS9LPRS365, and thermal monitoring is provided by an ADM1032 sensor. The audio amplifier is an APA2068.
A: The embedded controller is an ITE IT8512E.
A: The audio codec is a Realtek ALC662.
Q: What charging IC and architecture does this motherboard use?
A: The charging IC is an APM2556, supporting either battery or adaptor input.
A: The LAN controller is a Realtek RTL8101E.
| Brand | Elitegroup Computer Systems |
| Model | U40II |
| Project Code | U40II |
| Board Number | U40II1 |
| Revision | C |
| Date | Friday, December 07, 2007 |
| CPU Platform | Intel Merom |
| CPU Socket | Socket 478 |
| PCH / Southbridge | ICH8-M |
| North Bridge | Crestline |
| GPU Type | Integrated |
| Graphics Architecture | Intel GMA (Crestline integrated) |
| EC / KBC | ITE IT8512E |
| EC/KBC Package | ITE8512E |
| Audio Codec | ALC662 |
| BIOS / SPI Flash | SPI Flash ROM |
| Charging IC | APM2556 |
| Charger Architecture | Battery or Adaptor |
| Power IC(s) | ISL6261, OZ827, MAX8716, APM1084, APL1084, FIFT6137B, APM2510, OZ8138, L78L05 |
| RAM Type | DDR2 |
| RAM Architecture | SODIMM |
| RAM Quantity / Slots | 1 |
| Card Reader IC | RTS5158 |
| LAN IC | RTL8101E |
| WiFi / WLAN IC | Mini Card |
| Clock Generator | ICS9LPRS365 |
| Thermal Sensor | ADM1032 |
| Audio Amplifier | APA2068 |
U40II
U40II1
Merom
478
ICH8
IT8512E
ALC662
APM2556
APL1084
APM1084
APM2510
FIFT6137B
ISL6261
L78L05
MAX8716
OZ8138
OZ827
DDR2
RTS5158
RTL8101E
ICS9LPRS365
Clock Generator
ADM1032
APA2068
Audio Amplifier
U40II
U40II1
Merom
478
ICH8
IT8512E
ALC662
APM2556
APL1084
APM1084
APM2510
FIFT6137B
ISL6261
L78L05
MAX8716
OZ8138
OZ827
DDR2
RTS5158
RTL8101E
ICS9LPRS365
Clock Generator
ADM1032
APA2068
Audio Amplifier
