hp aio 18-1200br tpv arroyo3 6050a2516401-mb rev a02 12jul2012
This HP Arroyo3 motherboard, manufactured by TPV (Top Victory Electronics Co., Ltd.) with board number 6050A2516401 revision A02, is built around the AMD FT1 CPU platform paired with the AMD HUDSON D3L southbridge. The system utilizes two channels of DDR3 SODIMM memory and features an IT8519E embedded controller for system management. Audio is handled by the ALC269-VC codec, while networking is provided by the RTL8175E-CG/LED LAN controller. The graphics subsystem is managed by a SCALAR ANX3110, which also serves as an HDMI level shifter. Power delivery is based on a +19V DC-IN architecture with dedicated VDDCR_CPU and VDDCR_NB power ICs. The board also integrates WLAN/BT wireless connectivity and a card reader controller.
A: The board number is 6050A2516401, revision A02.
A: The embedded controller is an IT8519E.
Q: What is the charging architecture of this motherboard?
A: The system uses a +19V DC-IN charging architecture.
Q: What audio codec and LAN IC are used on this motherboard?
A: The audio codec is an ALC269-VC, and the LAN IC is an RTL8175E-CG/LED.
| Brand | HP |
| Model | Arroyo3 |
| Motherboard Manufacturer | TPV (Top Victory Electronics Co., Ltd.) |
| Project Code | Arroyo3 |
| Board Number | 6050A2516401 |
| Revision | A02 |
| Date | Tuesday, May 22, 2012 |
| CPU Platform | AMD FT1 |
| PCH / Southbridge | AMD HUDSON D3L |
| EC / KBC | IT8519E |
| Audio Codec | ALC269-VC |
| LAN IC | RTL8175E-CG/LED |
| RAM Type | DDR3 SODIMM |
| RAM Architecture | 2 Channel |
| Graphics Architecture | SCALAR ANX3110 |
| Charger Architecture | DC-IN +19V |
| Power IC(s) | VDDCR_CPU, VDDCR_NB |
| WiFi / WLAN IC | WLAN/BT |
| Card Reader IC | CARDREADER |
| USB Hub IC | USB3.0 CONN |
| HDMI Level Shifter | SCALAR ANX3110 |
