hp compal ls-4897p 2008-10-06 rev-0.1 odd transfer board 1
This Compal Electronics document covers the LS-4897P ODD transfer board (Multi bay) revision 0.3, dated 2008-10-06. The schematic details a sub-board designated as the Multi Bay (ODD side) board, which utilizes a TYCO_0-1735418-3_NR connector and a HOT BAR FFC interface with a 1.0mm pitch and 7mm pad. The design includes SATA signal routing and power delivery via +5VS. This is a proprietary Compal engineering drawing classified as Compal Secret Data.
Q: What is the board number and revision of this schematic?
A: The board number is LS-4897P, revision 0.3.
Q: What type of connector is used on the Multi Bay (ODD side) board?
A: The connector is a TYCO_0-1735418-3_NR, using a HOT BAR FFC interface with 1.0mm pitch and 7mm pad.
| Project Code | LS-4897P |
| Board Number | LS-4897P |
| Revision | 0.3 |
| Date | 2008-10-06 |
| Document Number | LS-4897P |
| Board Description | ODD transfer board(Multi bay) |
| Sub-board Description | Multi Bay(ODD side) |
| Connector | TYCO_0-1735418-3_NR |
| Connector Type | HOT BAR FFC |
| FFC Pitch | 1.0mm |
| FFC Pad | 7mm |
