Schematic hp compal ls-4897p multibay odd side schematic
BrandCompal
Project CodeLS-4897P
Board NumberLS-4897P
Revision0.3
Date2008-10-06
Document NumberLS-4897P
Board DescriptionODD transfer board(Multi bay)
This Compal LS-4897P revision 0.3 document, dated 2008-10-06, covers an ODD transfer board designed for a Multi bay configuration. The board is classified as Compal Secret Data and is the proprietary property of Compal Electronics, Inc. The schematic includes a Multi Bay (ODD side) board section with a HOT BAR FFC connector (pitch 1.0mm, pad 7mm) and a TYCO 0-1735418-3 connector. The document also references a related LS-4021P revision 0.3 project for a Fingerprint Circuit, as indicated in the Version Change List.
Q: What is the project code and board number for this ODD transfer board?
A: The project code and board number is LS-4897P.
Q: What revision is this Compal ODD transfer board schematic?
A: The schematic is revision 0.3.
Q: What is the document date for this LS-4897P schematic?
A: The document date is 2008-10-06.
  • HP=Compal LS-4897P MULTIBAY ODD SIDE.pdf
