File Request HP Compaq 6730b
xit01234
6050A2219901-MB-A03
Hello,
Wifi is whitelist on bios F17 and unable to upgrade. Attched bios F17.
I referenced searched on the web the motherboard model from the SKU Nmber KR971UT#ABA from bios to 486248-001 to 6050A2219901-MB-A03 please verify.
Thank you.
  • sp51317.zip
Hello,
Thank you.
  • 6730b fix.bin
xit01234
Hello,
The original file creates a folder with the HPQFlash.exe program and only flashes the original F17 bios. I tried renaming the your 6730b fix.bin to exe file but doesn't work. How to use this new bin file to flash the laptop?
Thank you.
you need program the bin file on motherboard with programmer device
then it will work
xit01234
Hello,
I was able to find the DOS Flash utility by downloading F14 bios from HP 6730b site. I replaced the bin and renamed. Copied the files to a FreeDos USB and flashed the 6730b. Powered Down and replaced the WiFi Card. Rebooted and received this message...
104-Unsupported wireless network device detected.
System Halted. Remove device and restart.
The bin file did not fix the problem. Thanks.
try this one :
  • update.bin
xit01234
Hello,
I flashed the update.bin no the bios reads as F20. I default bios to factory and installed new WiFi card. I get the same message...
The update.bin did not work. Thank you.
xit01234
Hello,
I flashed the update.bin now the bios reads as F20. I default bios to factory and installed new WiFi card. I get the same message...
unfortunately there is no other bios file for this device
all files have been sent
xit01234
Hello,
I'm unable to go back to F17, now that bios is F20. I have downloaded F20 bios and extracted the ROM.CAB to a zip file attached. Possible to try again as I do want to keep this HP 6730b Laptop. Thank you for you time and services.
  • hp6730b_rom_cab_f20.zip
here :
  • HP 6730b.bin
xit01234
Hello,
I tried the new bin file , same error message. Whitelist blocking new mini pci-e wifi card.
Thank you for your time and efforts.
Merry Christmas!
all files where extracted from main source
unfortunately there is no other file for this device
