Schematic hp compaq 8710p-8710w ls-3334p rev 0.1 fingerprint board schematic
compal ls-3334p rev 0.1 fingerprint board.pdf
BrandCompal
ModelLS-3334P Fingerprint Board
Document NumberLS-3334P
Revision0.1
Date2006-06-22
EC / KBCAES2501B-C-MF-TR-NI
EC/KBC PackageBGA48
EC/KBC ProgrammableYes
This Compal LS-3334P Fingerprint Board schematic, revision 0.1 dated 2006-06-22, is a dedicated sub-board designed for fingerprint authentication. The core controller is an AES2501B-C-MF-TR-NI fingerprint processor in a BGA48 package, which is programmable via its CLKSEL0, CLKSEL1, and CLKSEL2 pins for crystal/resonator or clock frequency selection. The board includes a fingerprint sensor interface, USB connectivity, and power management components such as the ATI4610AIGV-T1 voltage regulator. The design incorporates ESD protection and layout notes for optimal performance, with a 12MHz crystal providing the system clock.
Q: What is the main controller IC on this Compal LS-3334P fingerprint board?
A: The main controller is an AES2501B-C-MF-TR-NI fingerprint processor in a BGA48 package.
Q: Is the AES2501B controller programmable on this board?
A: Yes, the AES2501B is programmable, with CLKSEL0, CLKSEL1, and CLKSEL2 pins for selecting crystal/resonator or clock frequency options including 6MHz, 12MHz, 18MHz, 24MHz, and 48MHz.
  • HP Compaq 8710P-8710W=1=LS-3334P Rev 0.1 Fingerprint Board.zip
