hp compaq 8710w 8710p compal la-3331p_rev1.0 schematic
hp compaq 8710w 8710p=1=compal la-3331p_rev1.0.pdf
This Compal LA-3331P revision 1.0 motherboard, dated 2007-05-15, is built around the Mobile Merom uFCPGA-478 CPU platform with Intel Crestline_PM MCH and ICH8-M southbridge core logic. The system BIOS is stored on an ST M25P32 SPI flash ROM. Embedded controller functions are handled by an SMSC KBC 10706, with a separate SMSC LPC47N217 Super I/O for legacy I/O management. Memory configuration consists of two DDR2-SO-DIMM slots supporting dual-channel architecture at 667 MHz. Integrated audio is provided by an AD1981H codec paired with a MAX9710 amplifier. Networking capabilities include an Intel 82566MM Gigabit LAN controller and a Broadcom 802.11b/g WLAN module. The platform supports a discrete GPU via an MXM III connector. Additional notable components include an ICS9LPRS355 clock generator, Rico R5C583 CardBus and card reader controller, ADM1032ARMZ thermal sensor, SLB9635TTA TPM, and AES1610 fingerprint sensor.
A: The BIOS SPI flash is an ST M25P32.
A: The embedded controller is an SMSC KBC 10706.
Q: What is the memory configuration of this motherboard?
A: The motherboard supports two DDR2-SO-DIMM modules in dual-channel configuration at 667 MHz.
Q: What is the graphics architecture of this motherboard?
A: The motherboard uses an MXM III connector for discrete GPU support.
Technical data
| Project Code | LA-3331P |
| Board Number | LA-3331P |
| Date | 2007-05-15 |
| CPU Platform | Mobile Merom uFCPGA with Intel Crestline_PM+ICH8-M core logic |
| CPU Socket | uFCPGA-478 |
| PCH / Southbridge | Intel ICH8-M |
| EC / KBC | SMSC KBC 10706 |
| Audio Codec | AD1981H |
| BIOS / SPI Flash | ST M25P32 |
| BIOS Flash Exact Model | ST M25P32 |
| BIOS Flash Capacity | 32 Mbit (4 MB) |
| Charging IC | SLB9635TTA |
| RAM Type | DDR2-SO-DIMM |
| Thermal Sensor | ADM1032ARMZ |
| Card Reader IC | Rico R5C583 |
| LAN IC | Intel 82566MM |
| WiFi / WLAN IC | Broadcom 802.11b/g WLAN |
| Super I/O | SMSC LPC47N217 |
| Clock Generator | ICS9LPRS355 |
| Audio Amplifier | MAX9710 |
| Fingerprint Sensor | AES1610 |
| TPM | TPM1.2 |
| CardBus Controller | Rico R5C583 |
| Graphics Architecture | MXM III Connector |
| dGPU Chip Number | MXM III |
Technical data
LA-3331P
LA-3331P
Merom
ICH8
10706
AD1981H
ST M25P32
BIOS / EC Flash
SLB9635TTA
DDR2
ADM1032ARMZ
RICO R5C583
82566MM
LPC47N217
Super I/O
ICS9LPRS355
Clock Generator
MAX9710
Audio Amplifier
TPM1.2
TPM / Security IC
MXM III Connector
LA-3331P
LA-3331P
Merom
ICH8
10706
AD1981H
ST M25P32
BIOS / EC Flash
SLB9635TTA
DDR2
ADM1032ARMZ
RICO R5C583
82566MM
LPC47N217
Super I/O
ICS9LPRS355
Clock Generator
MAX9710
Audio Amplifier
TPM1.2
TPM / Security IC
MXM III Connector
