HP DM4 6050A2345401-MB-A03 Schematic
The Inventec MURRAY Zidane-UMA (PGA) motherboard, board number 6050A2345401-MB-A03 revision A03, is built around the Intel Arrandale CPU platform on Socket-rPGA989 with an HM55 PCH. The system uses DDR3 memory in two SO-DIMM slots. The embedded controller is an ITE IT8502E, and the audio codec is an IDT 92HD80. The BIOS is stored on a SPI ROM. Power management is handled by a combination of ICs including TPS51218, TPS51125, TPS51621, TPS51511, RT8015A, and PM6652, with charging controlled by a TI BQ24721C. Networking is provided by a Realtek RTL8111DL LAN controller, and wireless connectivity supports WLAN + BT. The HDMI interface uses a TI SN75DP139 level shifter, and the card reader is controlled by an AU6433 IC. Thermal monitoring is managed by an SMSC EMC1412 sensor.
A: The motherboard uses an ITE IT8502E EC/KBC.
A: The audio codec is an IDT 92HD80.
A: The charging IC is a TI BQ24721C_QFN_32.
A: The motherboard supports DDR3 memory in two SO-DIMM slots.
| Brand | Inventec |
| Model | Zidane-UMA (PGA) |
| Motherboard Manufacturer | Inventec Corporation |
| Project Code | MURRAY |
| Board Number | 6050A2345401-MB-A03 |
| Revision | A03 |
| Date | 2010/03/15 |
| CPU Platform | Arrandale (Socket-rPGA989) |
| PCH / Southbridge | HM55 |
| EC / KBC | ITE IT8502E |
| Audio Codec | IDT 92HD80 |
| Charging IC | TI BQ24721C_QFN_32 |
| Power IC(s) | TPS51218, TPS51125, TPS51621, TPS51511, RT8015A, PM6652 |
| RAM Type | DDR3 |
| LAN IC | RTL8111DL |
| WiFi / WLAN IC | WLAN + BT |
| HDMI Level Shifter | TI SN75DP139 |
| Card Reader IC | AU6433 |
| Thermal Sensor | SMSC EMC1412 |
| Document Number | 6050A2345401-MB-A03-8 |
| Drawing Number | A031310A23512-0-MTR |
6050A2345401-MB-A03
HM55
IT8502E
IDT 92HD80
BQ24721C (QFN-32)
PM6652
RT8015A
TPS51125
TPS51218
TPS51511
TPS51621
DDR3
RTL8111DL
WLAN / BT
SN75DP139
AU6433
SMSC EMC1412
6050A2345401-MB-A03
HM55
IT8502E
IDT 92HD80
BQ24721C (QFN-32)
PM6652
RT8015A
TPS51125
TPS51218
TPS51511
TPS51621
DDR3
RTL8111DL
WLAN / BT
SN75DP139
AU6433
SMSC EMC1412
