Schematic hp dv6 6000 flex h510ua1 hpmh-40gab6300-d schematic
hp dv6 6000=1=flex h510ua1 hpmh-40gab6300-d.pdf
BrandHP
ModelMH-10
Project CodeHPMH-40GAB6300-DD
Document NumberH510UA1
Revision1
DateThursday, December 30, 2010
CPU PlatformAMD Danube
CPU ModelDual/ Single Core
North BridgeAMD RS880M
South BridgeAMD SB820M
GPU TypeATI dGPU with Muxless Seymour/ Whistler
Graphics ArchitectureMuxless Hybrid: Seymour 64bit 15W + DDR3 x4 / Whistler 128bit 25W + DDR3 x8
EC / KBCITE ITE8518
Audio CodecIDT92HD80TA
BIOS / SPI FlashSPI BIOS
Charging ICBATT CHARGER
RAM TypeDDR3-SODIMM
RAM ArchitectureDDR III 1066/ 1333MHZ
LAN ICRealtek RTL8111E-VB-GR
WiFi / WLAN ICWLAN Half MINI-CARD
Card Reader ICRealtek RTS5209
USB Hub ICTI TUSB7320
dGPU Chip NumberSeymour XT: HPMH-10-0020000049G / Whistler Pro: HPMH-10-0020000050G
dGPU to UMA Conversion SupportMuxless Hybrid
Power IC(s)dGPU VCORE
Thermal SensorST Micro HP3D
HDMI Level ShifterHDMI
This HP MH-10 motherboard, documented under project code HPMH-40GAB6300-DD with document number H510UA1 revision 1 dated December 30, 2010, is built on the AMD Danube platform featuring an AMD RS880M North Bridge and AMD SB820M South Bridge. The graphics subsystem uses an ATI dGPU with Muxless Hybrid architecture supporting either a Seymour 64bit 15W or Whistler 128bit 25W GPU, with specific chip numbers HPMH-10-0020000049G for Seymour XT and HPMH-10-0020000050G for Whistler Pro. System memory consists of DDR3-SODIMM modules operating at DDR III 1066/1333 MHz. The embedded controller is an ITE ITE8518, and the audio codec is an IDT92HD80TA. Networking is handled by a Realtek RTL8111E-VB-GR Gigabit LAN controller, with wireless connectivity via a WLAN Half MINI-CARD slot. The board includes a Realtek RTS5209 card reader, a TI TUSB7320 USB 3.0 hub controller, and an SPI BIOS flash for firmware storage.
Q: What is the exact project code and document number for this motherboard?
A: The project code is HPMH-40GAB6300-DD and the document number is H510UA1, revision 1, dated December 30, 2010.
A: The embedded controller is an ITE ITE8518.
Q: What is the dGPU configuration and does it support Muxless Hybrid operation?
A: The board uses an ATI dGPU with Muxless Hybrid architecture, supporting either a Seymour 64bit 15W or
  • HP DV6 6000=1=Flex H510UA1 HPMH-40GAB6300-D.zip
