hp dv6 dv7 colossus 15-17 dis 11254-1 schematic
hp dv6 dv7=1=colossus 15-17 dis 11254-1.pdf
The Wistron Colossus 15/17 CR motherboard, project code 91.4ST01.001 and board number 11254 revision -1, is built around the Intel IVY Bridge-M CPU platform with rPGA989 socket and Intel PCH Panther Point-M southbridge. Graphics are handled by the Nvidia N13P GLG709/P2800 discrete GPU with DISCRETE OPTIMUS architecture, and the schematic explicitly notes DIS_OPT configuration with no stuff for discrete Optimus installation. The system memory consists of DDRIII 1600/1333 in dual-channel configuration across Slot 0 and Slot 1. The embedded controller is a KB9016QF, and the audio codec is an IDT92HD91. The SPI flash is 8MB. Power management is handled by a BQ24738 charger IC and multiple DC/DC converters including NCP3218G, TPS51461, RT8207MZ, RT8223M, RT8068A, VT13231, VT13234, and SN1003055RUWR. Networking is provided by a Realtek RTL8111F gigabit NIC and a 2.11a/b/g/n Bluetooth combo Mini-Card. The card reader uses a Realtek RTS5229 controller, and HDMI 1.4 level shifting is supported.
A: The motherboard uses an 8MB SPI flash for BIOS storage.
A: The embedded controller is a KB9016QF.
A: The schematic indicates DIS_OPT (Discrete Optimus) configuration with "No stuff" for discrete Optimus installation, meaning the discrete GPU path is depopulated by default.
A: The charging IC is a BQ24738.
Q: What is the graphics configuration on this motherboard?
A: The motherboard uses an Nvidia N13P
| Project Code | 91.4ST01.001 |
| Board Number | 11254 |
| Revision | -1 |
| Date | Wednesday, January 04, 2012 |
| CPU Platform | IVY Bridge-M |
| CPU Socket | rPGA989 |
| PCH / Southbridge | Intel PCH (Panther Point) |
| GPU Type | Nvidia N13P GLG709/P2800 |
| Graphics Architecture | DISCRETE OPTIMUS |
| EC / KBC | KB9016QF |
| Audio Codec | IDT92HD91 |
| BIOS / SPI Flash | SPI Flash 8MB |
| Charging IC | BQ24738 |
| Power IC(s) | NCP3218G, TPS51461, RT8207MZ, RT8223M, RT8068A, VT13231, VT13234, SN1003055RUWR |
| RAM Type | DDRIII 1600/1333 |
| RAM Quantity / Slots | Slot 0, Slot 1 |
| Card Reader IC | Realtek RTS5229 |
| LAN IC | Realtek RTL8111F |
| WiFi / WLAN IC | 2.11a/b/g/n Bluetooth combo Mini-Card |
| HDMI Level Shifter | HDMI 1.4 |
| dGPU Chip Number | N13P GLG709/P2800 |
| dGPU to UMA Conversion Support | DIS_OPT Schematic: No stuff |
| Document Number | A41103 |
91.4ST01.001
11254
IVY Bridge-M
PCH (PANTHER POINT)
DISCRETE OPTIMUS
KB9016QF
IDT92HD91
BQ24738
NCP3218G
RT8068A
RT8207MZ
RT8223M
SN1003055RUWR
TPS51461
VT13231
VT13234
DDRIII 1600/1333
RTS5229
RTL8111F
HDMI 1.4
N13P GLG709/P2800
91.4ST01.001
11254
IVY Bridge-M
PCH (PANTHER POINT)
DISCRETE OPTIMUS
KB9016QF
IDT92HD91
BQ24738
NCP3218G
RT8068A
RT8207MZ
RT8223M
SN1003055RUWR
TPS51461
VT13231
VT13234
DDRIII 1600/1333
RTS5229
RTL8111F
HDMI 1.4
N13P GLG709/P2800
