hp elitebook 2540p compal_la-5251p_rev0.9 schematic
hp elitebook 2540p=1=compal_la-5251p_rev0.9.pdf
The Compal LA-5251P revision 0.9 motherboard, dated 2010-01-04, is built around the Intel Auburndale BGA platform with Ibex Peak MTPM core logic. The system firmware is stored on an 8MB SPI ROM. Embedded controller functions are managed by an SMSC KBC 1098. Memory configuration consists of two DDR3 SO-DIMM slots supporting 1066/1333MHz modules in dual-channel architecture at 1.5V. Audio processing is handled by an IDT 92HD75 codec with a TPA6047A4RHBR amplifier. Networking is provided by an Intel Hanksville GbE controller. System monitoring includes an EMC2113 thermal sensor, and the card reader interface is managed by a Rico R5C835 controller.
A: The motherboard uses an 8MB SPI ROM for system firmware storage.
Q: What EC/KBC controller is used on the LA-5251P?
A: The embedded controller is an SMSC KBC 1098.
Q: What memory configuration does this platform support?
A: It supports two DDR3 SO-DIMM slots in dual-channel architecture, running at 1066/1333MHz with 1.5V.
| Board Number | LA-5251P |
| Revision | 0.9 |
| Date | 2010-01-04 |
| CPU Platform | INTEL Auburndale BGA with IBEX core logic |
| EC / KBC | SMSC KBC 1098 |
| Audio Codec | IDT 92HD75 |
| BIOS / SPI Flash | SPI ROM 8MB |
| RAM Type | DDR3-SO-DIMM X 2 DDR3 1066/1333MHz 1.5V Dual Channel |
| LAN IC | Intel Hanksville GbE |
| Thermal Sensor | EMC2113 |
| Card Reader IC | Rico R5C835 |
