hp hpmh-41-ab4000-d00g dm3 amd embedded with ati rs780mn&sb710 1
This motherboard is based on the AMD platform, utilizing the AMD RS780MN northbridge and AMD SB710 southbridge. The embedded controller is an ITE8502E KBC. Audio is handled by an IDT92HD81B1 codec, and networking is provided by a Realtek RTL8103EL-GR LAN IC. The system supports DDR3 667 and DDR2 667 MAX memory configurations. A card reader is integrated using the Alcor AU6433B52-GE controller. The charging circuit is managed by an RTM880N-796 IC. The board design is identified by project name HPMH-40GAB4000-D000D, dated August 17, 2009.
A: The embedded controller is an ITE8502E.
A: The audio codec is an IDT92HD81B1.
A: The LAN IC is a Realtek RTL8103EL-GR.
Q: What card reader controller is used on this motherboard?
A: The card reader controller is an Alcor AU6433B52-GE.
A: The charging IC is an RTM880N-796.
| Project Name | HPMH-40GAB4000-D000D |
| Document Number | HPMH-40GAB4000-D000D |
| Date | Monday, August 17, 2009 |
| CPU Platform | AMD |
| Northbridge | AMD RS780MN |
| Southbridge | AMD SB710 |
| EC / KBC | ITE8502E |
| Audio Codec | IDT92HD81B1 |
| LAN IC | RTL8103EL-GR |
| Card Reader IC | AU6433B52-GE |
| RAM Type | DDR3 667 / DDR2 667 MAX |
| Charging IC | RTM880N-796 |
