hp ls-4895p r05 20090706
This Compal Electronics LS-4895P revision 0.5 Switch Board schematic, dated July 6, 2009, is a proprietary engineering document. The board is designed as a serial interface switch board, utilizing a MAX3243ECUI+T transceiver in a TSSOP28 package for RS-232 communication. The design includes multiple serial port connectors and associated passive components for signal conditioning. The document is marked as confidential and proprietary to Compal Electronics, Inc.
Q: What is the document number and revision of this board?
A: The document number is LS-4895P, revision 0.5.
Q: What serial transceiver IC is used on this board?
A: The board uses a MAX3243ECUI+T transceiver in a TSSOP28 package.
| Document Number | LS-4895P |
| Revision | 0.5 |
| Date | Monday, July 06, 2009 |
| Board Type | Switch Board |
| Serial Transceiver | MAX3243ECUI+T |
| Serial Transceiver Package | TSSOP28 |
