hp mini 5102 gucci20 6050a2283001-mb-a03 mv 2010.02.22
The INVENTEC GUCCI 2.0 motherboard, board number CSA3451A02 revision A02, is built around an Intel Pineview CPU platform paired with an Intel Tigerpoint PCH. The system uses an SMSC 1098 EC/KBC and an SST25VF016B 16 Mbit SPI BIOS flash. Audio is handled by an ICS_92HD75B codec, while charging is managed by a TI_BQ24740 QFN-28 system charger supporting a main battery. Power regulation includes TI_TPS51610, APL5930, TPS51125, TPS51100H, and TPS51117 ICs. Memory architecture consists of dual DDR2 channels with one DDR2 SODIMM slot. Networking is provided by a MARVEL 88E8072 LAN controller, and the clock generator is an ICS9LRS3165/CK505M. An STMicro LIS302DL accelerometer is present, and graphics are integrated.
A: The BIOS flash is an SST25VF016B, a 16 Mbit (2 MB) SPI flash from SST.
A: The embedded controller/keyboard controller is an SMSC 1098.
A: The charging IC is a TI_BQ24740 in a QFN-28 package, supporting a system charger and main battery configuration.
A: The motherboard uses dual DDR2 channels with one DDR2 SODIMM slot.
| Brand | INVENTEC |
| Model | GUCCI 2.0 |
| Motherboard Manufacturer | INVENTEC |
| Project Code | GUCCI 2.0 |
| Board Number | CSA3451A02 |
| Revision | A02 |
| Date | 17-Dec-2009 |
| CPU Platform | Intel Pineview |
| PCH / Southbridge | Intel Tigerpoint |
| EC / KBC | SMSC 1098 |
| Audio Codec | ICS_92HD75B |
| BIOS / SPI Flash | SST25VF016B |
| BIOS Flash Exact Model | SST25VF016B |
| BIOS Flash Manufacturer | SST |
| BIOS Flash Capacity | 16 Mbit (2 MB) |
| Charging IC | TI_BQ24740_QFN_28 |
| Charger Architecture | System Charger & Main Battery |
| Power IC(s) | TI_TPS51610, APL5930, TPS51125, TPS51100H, TPS51117 |
| RAM Type | DDR2 |
| RAM Architecture | Dual DDR2 Channel |
| RAM Quantity / Slots | DDR2_SODIMM0 |
| Card Reader IC | Card Reader |
| LAN IC | MARVEL 88E8072 |
| WiFi / WLAN IC | WLAN |
| Clock Generator | ICS9LRS3165/CK505M |
| Accelerometer | STMicro LIS302DL |
| GPU Type | INTEGRATED GRAPHIC |
| Graphics Architecture | Integrated Graphics |
2.0
CSA3451A02
Intel Pineview
SMSC 1098
ICS_92HD75B
SST25VF016B
BIOS / EC Flash
SST
BIOS / EC Flash
TI_BQ24740_QFN_28
APL5930
TI_TPS51610
TPS51100H
TPS51117
TPS51125
DDR2
MARVEL 88E8072
WLAN#
ICS9LRS3165/CK505M
Clock Generator
Integrated Graphic
Integrated Graphics
2.0
CSA3451A02
Intel Pineview
SMSC 1098
ICS_92HD75B
SST25VF016B
BIOS / EC Flash
SST
BIOS / EC Flash
TI_BQ24740_QFN_28
APL5930
TI_TPS51610
TPS51100H
TPS51117
TPS51125
DDR2
MARVEL 88E8072
WLAN#
ICS9LRS3165/CK505M
Clock Generator
Integrated Graphic
Integrated Graphics
