hp mini 5102 gucci20 6050a2283001-mb rev ax3 pv 2009.11..02
The Inventec GUCCI 2.0 platform, model AX2, is built around an Intel Pineview CPU paired with an Intel Tigerpoint PCH. The motherboard uses a dual-channel DDR2 memory architecture with a single SODIMM slot. The system is powered by a TI BQ24740 charging IC and managed by an SMSC 1098 EC/KBC. The BIOS is stored on an SST25VF016B SPI flash IC. Audio is handled by a 92HD75B codec, and networking is provided by a Marvel 88E8072 LAN controller. The clock generator is an ICS9LRS3165/CK505M, and the card reader interface is managed by an STMicro LIS302DL accelerometer. The board is documented under number CSA3451, revision A, with document number 1310A2230401-0-MTR.
A: The BIOS is stored on an SST25VF016B SPI flash IC.
A: The EC/KBC is an SMSC 1098.
A: The charging IC is a TI BQ24740.
A: The motherboard uses a dual-channel DDR2 architecture with one SODIMM slot.
| Brand | Inventec |
| Model | AX2 |
| Project Code | GUCCI 2.0 |
| Board Number | CSA3451 |
| Revision | A |
| Date | 30-Sep-2009 |
| Document Number | 1310A2230401-0-MTR |
| CPU Platform | Intel Pineview |
| PCH / Southbridge | Intel Tigerpoint |
| EC / KBC | SMSC 1098 |
| Audio Codec | 92HD75B |
| BIOS / SPI Flash | SST25VF016B |
| Charging IC | TI BQ24740 |
| RAM Type | DDR2 |
| RAM Architecture | Dual DDR2 Channel |
| RAM Quantity / Slots | DDR2_SODIMM0 |
| LAN IC | Marvel 88E8072 |
| Card Reader IC | STMicro LIS302DL |
| Clock Generator | ICS9LRS3165/CK505M |
