hp_pavilion_22-b_series_aio quanta_molokai_n91a_dan91amb6d0_dr-bios.com hp_pavilion_22-b_series_aio quanta_molokai_n91a_dan91amb6d0_dr-bios.com schematic
hp pavilion 22-b series aio=quanta molokai n91a dan91amb6d0.pdf
The HP Molokai motherboard, manufactured by Quanta Computer Inc. (Board Number 154, Revision 1A, dated January 18, 2016), is built on the Intel Braswell-M platform with a BGA1170 CPU SoC rated at 6.5W TDP. The discrete graphics solution is an N16V-GMR1 GPU with dedicated DDR3 VRAM. System memory consists of two DDR3L SODIMM slots supporting up to 8GB per channel at 1600MT/s. The embedded controller is an IT8887, and the audio codec is an ALC3252. Power management is handled by a combination of ICs including the RT6575AGQW, RT8231B, RT5041A, RT8175A, TPS51363, APL3523A, and RT8812A. The board features an RTL8161GSH-CG LAN controller, a GL850G-50 USB 2.0 hub, an RTS5145 card reader, and an RTD2136 DP to LVDS converter. The BIOS is stored on a ROM IC, and the platform supports WLAN via an NGFF module.
Q: What EC/KBC is used on this HP Molokai motherboard?
A: The embedded controller is an IT8887.
Q: What is the discrete GPU on this motherboard?
A: The discrete GPU is an N16V-GMR1 with dedicated DDR3 VRAM.
Q: What audio codec is used on this board?
A: The audio codec is an ALC3252.
Q: What LAN controller is present on this motherboard?
A: The LAN controller is an RTL8161GSH-CG.
| Brand | HP |
| Model | Molokai |
| Motherboard Manufacturer | Quanta Computer Inc. |
| Project Code | HP-Molokai |
| Board Number | 154 |
| Revision | 1A |
| Date | Monday, January 18, 2016 |
| CPU Platform | Intel Braswell-M |
| CPU Model | Intel Braswell (TDP 6.5W) SoC |
| CPU Socket | BGA1170 |
| GPU Type | N16V-GMR |
| Graphics Architecture | N16V-GMR (PCIE I/F) |
| dGPU Chip Number | N16V-GMR1 |
| EC / KBC | IT8887 |
| Audio Codec | ALC3252 |
| BIOS / SPI Flash | ROM |
| Charging IC | RT6575AGQW |
| Power IC(s) | RT8231B, RT5041A, RT8175A, TPS51363, APL3523A, RT8812A |
| RAM Type | DDR3L |
| RAM Architecture | DDR3 L Channel A, DDR3 L Channel B |
| RAM Quantity / Slots | SODIMM1, SODIMM2 |
| Card Reader IC | RTS5145 |
| USB Hub IC | GL850G-50 |
| LAN IC | RTL8161GSH-CG |
| WiFi / WLAN IC | WLAN (NGFF) |
| HDMI Level Shifter | RTD2136 |
154
Braswell-M
CPU Model
N16V-GMR
N16V-GMR (PCIE I/F)
N16V-GMR1
GPU Chip
IT8887
ALC3252
RT6575AGQW
APL3523A
RT5041A
RT8175A
RT8231B
RT8812A
TPS51363
DDR3L
RTS5145
GL850G-50
RTL8161GSH-CG
RTD2136
154
Braswell-M
CPU Model
N16V-GMR
N16V-GMR (PCIE I/F)
N16V-GMR1
GPU Chip
IT8887
ALC3252
RT6575AGQW
APL3523A
RT5041A
RT8175A
RT8231B
RT8812A
TPS51363
DDR3L
RTS5145
GL850G-50
RTL8161GSH-CG
RTD2136
