hp pavilion dv2000 wistron_tibet_revsa schematic
hp pavilion dv2000=1=wistron_tibet_revsa.pdf
The Wistron TIBET motherboard, documented under A3144 dated August 14, 2007, is built around an AMD NPT Processor Rev. GS1 package paired with an nVIDIA MCP67 southbridge. System power management is handled by MAX8734A, MAX8743, and MAX8760 DC/DC converters, with battery charging controlled by a MAX8725 charger IC. The embedded controller is a WPC8763, and audio is provided by a CX20549-12Z HD Audio codec. Memory configuration supports DDRII 667/800 across two slots arranged as Channel A and Channel B. Connectivity includes a Marvell WLAN controller, an 88E3018 10/100/1000 PHY for Ethernet, and an R5C833 card reader supporting 5-in-1 media and 1394.
Q: What is the project code and document number for this motherboard?
A: The project code is TIBET, and the document number is A3144.
A: The embedded controller is a WPC8763.
A: The charging IC is a MAX8725.
| Project Code | TIBET |
| Document Number | A3144 |
| Date | Tuesday, August 14, 2007 |
| CPU Platform | AMD NPT Processor Rev. GS1 package |
| PCH / Southbridge | nVIDIA MCP67 |
| EC / KBC | WPC8763 |
| Audio Codec | CX20549-12Z |
| Charging IC | MAX8725 |
| Power IC(s) | MAX8734A, MAX8743, MAX8760 |
| RAM Type | DDRII 667/800 |
| RAM Architecture | Channel A, Channel B |
| RAM Quantity / Slots | Slot 0, Slot 1 |
| Card Reader IC | R5C833 |
| LAN IC | 88E3018 |
| WiFi / WLAN IC | Marvell |
